Question about Jenn-Air JGC7536 Gas Cooktop
Clicking sound whenever I turn on a burner
I have a 4 year old Jenn_air gas cooktop. For the past couple months, whenever I turn on a burner, I get a clicking noise. Wondering what might be the cause of this.
  • bill628 Nov 15, 2008
    We have the same problem---but also have persistent clicking sounds from neighboring burners which continue after the selected burner is ignited. Can we fix this or will a service representative be necessary?
  • Anonymous Mar 16, 2009
    I have a GE gas cooktop. Clicking noise occurs and one flame port is weak -- this happens on more than one burner. And, if I look at the burners which are off during this time, I see a faint spark coming from underneath the ceramic disks.
  • 3 Answers
It would be the automatic ignition on it it may be earthing under the burners
Posted on Jul 25, 2007
  • Seamistfix Jun 02, 2012
    So how do you remedy the problem please?
SOURCE:
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Hello- Will In Houston Teas
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
There is no problem. The click your hearing is the spark module igniting the gas. The clicking will only occur while the know is turned to ignite and will stop after your turn the knog to any other setting.
Jun 17, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Air JGC7536 Gas Cooktop Logo
285 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Norman Worley
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
