HP LaserJet 4p Printer Logo
Anonymous Posted on Dec 16, 2012
Connecting with usb port
My computer only has usb printer ports, how can I connect this printer
  • Anonymous Dec 16, 2012
    This printer only has 2 types of ports, the large multi pin (old style port) and a 7 pin port
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7302
Points
Try a usb/
Parallel Printer Adapter Cable
cable you can find them at office supply stores or others such as walmart.
http://www.walmart.com/ip/15075022?adid=22222222227000586714&wmlspartner=wlpa&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem
    Thanks, I didn't know they existed! Yeah!!
5 Related Answers
iqbal_del
Iqbal Husain
  • 655 Answers
  • Posted on Apr 15, 2008
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Anonymous
  • 4 Answers
  • Posted on Jun 05, 2008
SOURCE: windows xp with not recongise HP Laserjet 6p when plugged into a usb port
When it shows the message new hardware found click on "start" then click on "printers and faxes"Select the option on right side 'add printer" or select from file menu "Add printer" click next if insert installing CD Disk which came with Printer written Divers then click next now computer will start looking for Printer's Driver
other Subjection is
when it shows new hardware found message click on that message Insert Divers CD which came with that Printers Select the option to install driver from CD
Another subjection is Install the CD which came with Printer
Actual you don't have to any thing Insert CD It will auto play and
start installing just read the caption and select the alternatives
Best Of luck
antiochpc
Kevin Shafer
  • 1314 Answers
  • Posted on Dec 12, 2008
SOURCE: OfficeJet R40 printer cable with a USB connection
Yes there is. This is what you need.
Thanks and please take a moment to rate as fixya.
Anonymous
  • Posted on Jun 01, 2009
SOURCE: Trying to scan, but keeps on saying USB port not connected
it is not inserted properly
Anonymous
  • 2306 Answers
  • Posted on Jul 21, 2009
SOURCE: HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
2answers
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
1helpful
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Incorrect port message with canon lbp2900
Look in the Printer Properties for a Virtual USB port; an LPT1 port is a parallel port, seldom included on newer computers. The software CD should have installed a USB port, and associated the printer with that port.
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
How to map usb ports USB1, 2, etc.
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
1helpful
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
2answers
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Section "Connect Your Printer"
hi the computer is asking youto connect the printer USB cable to a USB port. first you have to connect the prnter to the USB port and wait to detect the printer. if the printer is not detected, the connection is not proper or the USB port is not active. use another port and try
thanks
k24674
Grand Canyon Tech
Grand Canyon Tech
