Question about HP DeskJet 5150 InkJet Printer
Hp deskjet 5150, ink carriage will not move, says there is a paper jam but there is not
    Genius:
  • 2,985 Answers
Shut it down, remove power and USB cord.
Whilst in this state thoroughly check for paper debris in the paper track.
Then power up one more and do not connect USB
Try for test page[See your Manual]
Posted on Jan 14, 2009
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
My hp D2460 inkjet printer never stop blinking and not printing
Time to change the ink cartridges
Or check for any paper jam
and wether the carriage is moving perfectly
if everything above is OK
its time to get a new printer....
Feb 21, 2011 | HP Deskjet 2460 InkJet Printer
Have a inkjet 5150 when trying to print carriage jams makes grinding noise but does not load paper
It is requiring servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | HP DeskJet 5150 InkJet Printer
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
Ink carriage will not move
Try moving the carriage back to the left again and see if that helps.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | HP DeskJet 1200c InkJet Printer
Hp deskjet 5150 paper jam
u have to need to do change the printer roller
Sep 01, 2008 | HP DeskJet 5150 InkJet Printer
Paper jammed
Usually tear drop means 'out of ink'
Apr 02, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
238 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
