Question about Dell Vostro 1500 Notebook
Key strokes slow response
When I type a word, there is a slight delay before it shows up on the monitor. Dell can't figure it out. This slows the typing speed considerably.
  • 5 more comments
  • bgat2206home Jan 14, 2009
    A second problem is that once in a while, I try to turn off my laptop but it won't shut down. I have to disconnest the battery for a few seconds. Dell can't come up with an answer.
  • bgat2206home Jan 19, 2009
    I still can not get the words on the monitor to keep up with the key strokes. There is a delay which causes a slow down in the typing process.
    What ever I type on my Dell Vostro 1500 keyboard, it shows up moments later on the screen. I had the laptop reformatted but still no change.
    No matter where I type, either on a web site or word processor, the problem still exists. I had a computer tech turn off all unnecessary programs but there was no change to the original posted problem.
    I have 2 Gig of memory installed. That should be sufficient.
    I've done all the maintenance such as deleting Temp files and defraging. That is done weekly by Live One Care.
  • bgat2206home Jan 21, 2009
    I've tried all your suggestions and even discussed it with a computer repair service. The problem still exists no matter where I type. That includes internet, e-mail, word processor. This is quite frustrating.
  • bgat2206home Jan 31, 2009
    I reformatted my hard drive, reinstalled Windows XP and all is well.
    Thanks
    Bob Remp
  • Dell Master
  • 19,396 Answers
Slow response is a defective keyboard ribbon cable, or a defective keyboard, the part must be replaced.
Posted on Jan 23, 2009
  • 716 Answers
Hit Ctrl Alt Delete And See What Your Cpu Usage Is At While Typing.
Please Let Us Know The Result
Posted on Jan 21, 2009
    Master:
  • 416 Answers
1. Most probably it is a virus. Chek it for viruses firs. If you have McAfree it can slow down the PC when ther is a virus. If cleaning failed you need to reinstall softwear.
2. physical memory is low
3. Also check the virtual memory: control panel - system - settings -performance - virtual memory. Try to increase it
Good Luck
    Top Expert:
  • Dell Master
  • 77,499 Answers
Are u running allot of background programs? if so type in MSCONFIG in the run menu and follow instructions, and shut off all the programs that u can. these programs will still be available but will only start running when u request that program, this should speed the system up.
    Sergeant:
    Champion:
  • 435 Answers
Is the boot up time normal? If not, the motherboard might be faulty.
    Scholar:
  • 160 Answers
Just reinstall the software again and properly.also format the laptop if its the problem after reloding the software.
Posted on Jan 19, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest you try:
  • BIOS reload or update;
  • Chipset reload or update;
  • or run the Dell Diagnostics.
All of the above are available at the Dell Downloads & Support page.
Pls post back result(s). Good luck and Thank you for using FixYa.
    Genius:
  • 2,920 Answers
My dell is the same way you can type a word and it takes a minute for the word to appear,,,its a flaw in the dell systems that they wont correct...i tried for several months to get them to send me a different computer and they refused even hough im paying 1000.00 for this one. they told me its just the way it is
  • Ronnie Houston Jan 22, 2009
    dell is notorious for slowness on the keyboard to the screen.ive had several of them and they were all the same way. nothing you can do but accept and live with it
  • Dell Master
  • 4,806 Answers
Hi there
May i ask if this only happens on-line or if it happens across the board?
If its only happening on-line, the reason is your java script needs updating and this should resolve the problem (sometimes with the machine itself) a flash update may also be required.
If its happening across the board ( the whole PC ) its one of 2 things.
1. there is a fault with the keyboard, degraded wire for example. try another keyboard
2. A slight fault with system memory due to build up of dust, Take out the memory and clean the dust away from the contacts and the slots and re-seat.
Good luck
    Brigadier General:
  • 5,158 Answers
I went thru this same issue with another asker for two days ... you need to increase the amount of memory your computer has.
Robert
  • Roberta Smith
    Roberta Smith Jan 19, 2009
    you may also wish to try... start menu... control panel... keyboard... you can control the repeat rate in there... tho i suspect in the long run you will indeed find it a memory issue
    President:
  • 1,990 Answers
Welcome to Fixya! OK, I have heard this about a Few Dell Laptops. This is a Problem with the Processor. You will have to take it to an Authorized Service Center and Get it Replaced with a New Processor.
Posted on Jan 14, 2009
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    Have you triedto Defragment and Clean out your Temp. Files?????
  • Dell Master
  • 13,433 Answers
I would suggest you reload the windows into the laptop from the recovery cd or from the original windows installation cd.
If you have a slow writing speed on the internet browser another browser might solve the problem.
it may be caused by too many programs runing on the background or a hardware fault generating interupt requets etc. I would need to have a closer look at the laptop to know more.
    Sergeant:
    Scholar:
  • 199 Answers
Try the same with external keyboard connected and check out.
6troubles codes reportd;PO133N2 SENSOR CIRCUIT SLOW RESPONSE
Don't know the vehicle you have ,so if your
front or upstream oxygen sensors are over
100,000 miles, they need changing, on all
your vehicles ,front only, leave rear monitors
until the converters wear out at 12 years or so
Then you can diagnose what ever is left
You got slow & lean sensors
Their old & tired & lost their switching
ability
Google the codes & read up
Change Spark Plugs every 3 years
Clean MAF Sensor-CRC MAF Cleaner
New Air Filter
Mar 13, 2013 | Ford Cars & Trucks
Camera is slow
Use a faster SD card. The write speed number is what you look for. The greater the number the better the card.
Mar 13, 2017 | Nikon Coolpix 3200 Digital Camera
It types very slow as if the keys are sticking and no dirt is under keys changed delay settings still don't type any faster what could be the problem.
try taking the keys off and reattaching them if that fails it must have either slow reactions or dodgy circuitry
Aug 21, 2011 | Computers & Internet
Dell Keyboard/Mouse Lag
Check your ease of access settings from the control panel. Make sure you don't have any keyboard and mouse settings that make for slow stroke response.
Mar 31, 2010 | Dell 0Y3740 Keyboard
When typing the strokes are very slow or delayed
There are keystroke delay setting in bios or in control pannel -- keyboard option. set it to minimum
Jan 16, 2010 | Acer Aspire 3000 Notebook
Keyboard very slow
In control panel (classic view) Click the kyboard icon. and configure repeat delay and speed
Hope it helps.
Sep 10, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Delayed response for keys
go into your control panel (classic view if you are using vista)... click on the keyboard icon... you can change the delay rate there
Robert
Please take a moment to rate this solution... thanks
May 22, 2009 | Dell Inspiron 1501 Notebook
Spaces appearing while typing.
You could try slowing the guilty computer's keyboard response speed;
- Open the Control Panel - Open the Keyboard section
Adjust repeat rate and delay to different values and try -
Sep 30, 2008 | Broderbund Mavis Beacon Teaches Typing...
Delay in clearing screen; also delay in number appearing after entry
The same thing happened to me. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard, and it works perfectly now!!!!! I hope this helps.
Sep 04, 2008 | Texas Instruments TI-84 Plus Calculator
Dell Vostro 1500 Notebook Logo
18 people viewed this question
Alun Cox
