Question about Marantz SR-7200 Receiver
Tone and bass adjustment
Hi there, I recently purchased a URC-7556 One For All universal remote for use with my Marantz SR7200 surround receiver (we were burgled and the thugs stole the remote, but left the amp behind-go figure). The remote works well with all systems and all the peripherals, but I cant access bass and treble adjustments. I believe I should also be able to adjust the internal equaliser settings through the main menu. The original remote had a screen and jog dial command selector. The One For all remote function code for the amp is 1289 and shows menu selections on the T.V screen.selections on original remote with AMP function selected on jog dial command were:
7 TRB+ to increase treble
8 RTB- to decrease treble
9 BAS+ to increase bass
0 BAS- to decrease bass.
I never tried adjusting equaliser, but if possible I would like to give it a bash
Thanks in advance for your attention to my issues.
Glen Dixon
Muldersdrift
South Africa
4 Suggested Answers
  • 579 Answers
SOURCE: Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from mcminone.com or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Posted on Jan 12, 2008
  • 11800 Answers
SOURCE: Hello, I have recently purchased a
You don't get the OSD on the screen because either the HDMI cable for the TV isn't plugged in the OUT plug (the one on the right) or the tv isn't set on the correct AV source (it should be n HDMI1 - if you have plugged the cable correctly on the tv).
Posted on Aug 21, 2010
joeguest2
  • 2080 Answers
SOURCE: I want to adjust treble
To change the TREBLE or BASS using the remote control unit, try the following:
To adjust the tone, press the AMP button and press the > button until PAGE3 is displayed.
To adjust the bass effect,
press BASS+ (D2) or BASS- (D3).
To adjust the treble effect,
TREB+ (D4) or TREB- (D5).
The tone control function can work in the AUTO
Surround, Stereo, Dolby Pro Logic IIx , DTS,
DTS-ES, and Multi Ch. Stereo mode.
Thank you and good luck.
Posted on May 16, 2011
I have Kenwood 106vr receiver, still working but lost remote control. Is there other way to adjust the BASS & TREBLE directly in the unit?
Hello
Not possible to adjust the tone without the remote.
if you have the possibility for a universal remote like "Logitech" remotes its Recommended for such cases, that will be easier for you to control the the AVR system.
Jun 13, 2016 | Kenwood Audio Players & Recorders
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
I need a code for my logik L19DIGB10 using a URC-7556 remote Please can anyone help me
Hello
Setup codes for Logik TV with one for all URC 7556 remote control are:
0011 0698 0060 0773 0009
0193 0264 0371 0001 0880
1217 1037
OK.
Jul 28, 2011 | Televison & Video
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
UK, I have a sr7200 but no remote! Are there any compatable ones out there? I have been quoted £250.00 for a replacement
I bought a RC3200 programmable remote after my dog chewed the origional unit. £30 off ebay, works a great. It comes preprogrammed for all Marantz units. Only problem is that it is a bit hard on batteries.
Nov 02, 2010 | Marantz SR-7200 Receiver
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
I have a Tevion 19" LCD TV/DVD Combi with built in freeview. Model number 1961hdt. The remote that came with it is not working and I have a oneforall universal remote, model no. URC-7556. The problem...
I still haven't found the code, but I managed to find a telephone number for a warranty centre that is able to replace the original remote control.
Jun 19, 2008 | Televison & Video
Reciver need to adjust bass or trebel
Hi Brent
hhmmmm, I searched through the manual to find this info for you. It appears that the tone adjustments are initiated by the "tone" button on the REMOTE. I could not find any reference to there being a button to do same on the front of the unit. Odd, but there you go.
  1. Use the tone key(on remote) to get "tone" up on the front of the unit.
  2. Then using the multi up-down keys, turn the "tone on".
  3. Once you have got to here, use the tone key to select "bass" or " treble"
  4. Using the multi up down keys, adjust the tone controls to your liking with the multi up down keys
you can download the manual from
http://www.retrevo.com/s/Kenwood-VR-60RS-Receivers-review-manual/id/480bh239/t/1-2/
Just enter your email address and away you go. Good Luck. A "FixYa" rating would be great for my time to research this for you.
regards
Graeme
Feb 16, 2008 | Audio Players & Recorders
Marantz SR-7200 Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
