Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Power light blinking
Power light keeps blinking and wont stop on none of the other lights are on either.
  • barmahvik Jan 30, 2009
    Is this problem common and why ? I have 2 SB5100 's with the same problem .Power light blinking and no other lights. I have a third modem SB5100 when I connect this modem to same connection as others were it works perfectly.So problem is definitely modem related. Any assistance would be appreciated.
Modems are not listed with your server.( not registered )
Posted on Feb 10, 2009
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
Ws-65611 wont power on
Most likely bad caps on the dm board.
Sep 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Jan 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Toner light won't stop blinking
Try resetting it, open front cover hold down silver button, all lights should flash rotatingly, when stopped turn off and on and close door.
Oct 09, 2007 | Lexmark E330 Laser Printer
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
300 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
