Question about Brother IntelliFAX 4100 Laser Fax
Faded prints about 2" in from the margin
My fax is working properly except for the prints that come out (either recieved faxes or copies) have a faded line that is about 2" in from the left side margin. I have changed the drum and the problem is still occurring.
1. How often does this drum have to be changed as there is no message telling me to change it.
2. can i fix this faded line in any way??
  • Anonymous Mar 20, 2014
    when copy or fax is printed it is missing left side of paper faded out vertically
    faded on left side of paper copy or fax
  • 56 Answers
{You used the term "drum". This may indicate a roll type of toner rather than a cartridge style of toner. The following tip is for a cartridge style.}
I get much the same symptom when my HP laser cartridge is running low, and no, it doesn't have a "low toner" indicator either. I get by a little longer with mine, long enough to get out and buy a new one that is, by removing it, holding it over a garbage can at an angle and firmly tapping on it to loosen any compacted toner. I then turn it back horizontally and gently shake it back and forth to evenly distribute the remaining toner through the cartridge and reinsert it into the printer. This usually gets me nice, even prints back and extends the life of the cartridge. I can usually get a few extra weeks out of it by doing this two or three times.
Posted on Jan 14, 2009
It does not produce a dialing tone and it doesn't fax nor recieve
Here are some things to check:
1. Is the unit attached to a direct line (not one that goes through a local PBX)? Many fax machines have problems with internal connections.
2. Is the phone line connected to the proper port? The port for the external phone normally will have a picture of a handset. The other port is used to connect to the phone outlet.
3. Try a new phone cable between the fax and the phone outlet.
Here is a link to the user manual if you do not have one:
Apr 29, 2015 | Brother Mfc-8220 Laser Multi-Function...
What causes letters to fade 3 inches in from the left margin, in a vertical line down the page, and how can I fix it?
Does this happen when copying or printing or both? If both then likley you have a defective cartridge, or something in the printer is blocking the scanner. Try gently shaking the cartridge to see if that helps. If it does, then either the toner is clumping or the cartridge is getting empty. If this only happens when making copies then probably the scanner glass is dirty.
Jan 26, 2015 | Samsung SCX 4623F - multifunction fax /...
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
HP 5780 will not receive a fax.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } There would not be problem in phone line. please slect slect appropriate option in data fax mode.
slect it to the recieving mode.
hopefully it will work fine
Sep 03, 2009 | HP Officejet J5780 All-In-One Printer
Copystar cs-c2520 i have a faded line down the center when i copy only not when i print or recieve a fax.
Either a problem with the document feeder or something on the glass. If it's faded it may just be a roller not pushing the paper onto the scanning area properly.
Jul 20, 2009 | Copystar Office Equipment & Supplies
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Transmition problem
Yes. If you can print an internal report, but not copy or fax properly then the scanning unit is the problem
Dec 09, 2007 | HP 1010 Plain Paper Inkjet Fax
The fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Dec 04, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Brother IntelliFAX 4100 Laser Fax Logo
221 people viewed this question
James Cagle
James Cagle
Jim Keysor
