Question about HP Photosmart C5280 InkJet Printer
Hp c5280 strip encoder part #c9058-80029
Strip encoder broke need instructions to install a new one.
  • justice28 May 06, 2009
    hello I'm alix and I have a HP photosmart D5160 and the c9058-80029 strip broke and my printer is not even working can somebody tell me what I have to do.
    Thank You
Damampreet,
In all due respect, I have known a couple of people who have placed their encoder strips back on their printers and had no problems with it working again.
Posted on Apr 09, 2014
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
nourahm
SOURCE: Replacing encoder strip om Lexmark X6170
First unplug your printer...
Lift your printer top, like you are going to change your ink cartridges.
Unplug your scanner & control panel by disconnecting the 3 ribbon cables
Then, you will need a screwdriver (philips head). remove the screws (about 4) from the inside housing cover.
After you have this cover off...
You should be able to see the sides of the cartridge. Take your encoder strip (gently) and thread it through the back of the cartriidges. Note: There are small slits on the side where you can thread.
If the encoder strip has come completely off (there should be tension if it is connected), you will have to located the right and left "pins" to attach it back to. I have a lexmark x-2500 so, mine are on the metal frame. The right end (arrow up) attaches to a metal strip which points straight towards you (a part of the metal frame) with a small notch at the right end and on the left end there's a type of "punchout" pin which is a part of the metal frame. I had to slightly bend the right end pin to the right, just enough to create some tension & keep the encoder strip from popping back off. The left end pin should already be bent out to the left.
Hopefully, this helps someone
Posted on Jun 05, 2009
My Hp z6100 carriage jamms in the middle along the encoder strip during printing and gives me error 86:01. I have tried cleaning the encoder strip and still having the same problem
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Jul 29, 2011 | HP Designjet Z6100 InkJet Printer
Cannot align cartridge
ok, now clean the encoder strip with clean cotton. encoder strip found and the back of the printer ink assembly look like a plain white plastic. wipe that till it clean.
Apr 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Scanner glass has broken into many pieces, do i need 2 buy a new printer??? or can i buy glass replacement???
I would contact HP support directly (here) to ask about this.
Many HP printers have and encoding strip on the back side of the glass, like an IPC, that the scanner must read in order to complete alignment. Without it your printer could be disabled.
So I would be hesitant to replace the glass with ordinary glass, unless you saved that strip from the underside of the old glass.
I'm not sure whether this applies to your model, but just to be safe, check with them.
Good luck.
Your product home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 31, 2009 | HP Photosmart C5280 InkJet Printer
Printer carriage not working properly on Photsmart c7200
I think the encoder strip has have the problem .try clean it with a cloth ..maybe the carrier cannot read the strip because of the dirt..the encoder strip is the one that hold the carrier or the cartridge holder... if the problem still persist:
you need to replace it ..with a new one....
May 19, 2009 | HP Office Equipment & Supplies
HP Photosmart c5280
Make sure to check all the way to the right and left inside. I ussually find paper loose in either of those ends. Then check your encoder strip which is the plastic strip that the carriage slides on. This may be dirty causing this issue. Use a soft paper towel and alcohol. Windex is okay to but may leave streaks on it and give same issue.
Dec 09, 2008 | HP Photosmart C5280 InkJet Printer
HP930C white strip behind ink cartridges coiled
the strip has to be replaced for sure .you will get that strip from any computer /printer reparing engineer as it is not available in the local market you will have to call the tech at your place and he will do it for you and it will be proper.it will cost you near to $10 for the new strip and that strip is called the encoder strip.
Oct 01, 2008 | HP DeskJet 930cm InkJet Printer
Hp g85 all in one
The "plastic strip" is the position encoder of the print head, it holds itself in place by two latches, one is fixed and the other is flexible, you have to put the encoder in the flexible latch first by holding it at an angle and then in the fixed one, probably you'll have to disassemble the MFP to have access and a better view of the parts.
Apr 27, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Strip encoder 7410 hp all in one printer
Not sure about the smoking thing...to replace the encoder strip will require fairly extensive disassembly. There are no repair manuals available for any of HP's Inkjet machines because all repairs or replacements are depot repairs (u send them in). We service all of their machines. We have an extensive used part inventory where we are able to fix most all of their inkjet line. If you were to bring this machine in to our shop, the repair would cost you $65 if its only replacing the encoder strip.
Inkworks
866-381-0541
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Encoder strip part c8941-80005
Feb 24, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C5280 InkJet Printer Logo
467 people viewed this question
Seeker5211
Seeker5211
