Question about RCA F32632SB 32" TV
Lost channels 2 through 52
I think our Niece reconfigured our TV. We have an RCA F32632SB TV that was working fine until our played with the buttons on the front. The cable comes in via coax from a digital tuner on channel 3. Tried another TV and everthing works fine, so I am pretty sure that the cable box is fine. Routed the cable directly from the wall to the TV, bypassing the cable box, and ran the autoprogram and we only get channels 52 and above. Channels 50 and 51 don't have anything on them. Tried running the cable directly to another TV, bypassing the cable box, and all the channels are available. We tried unplugging it. Went into the menu under the setup tab and selected autoprogram, with the same problem. Any suggestions?
    Novelist:
    Champion:
  • 236 Answers
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Posted on Jun 16, 2007
Why does my RCA f32632sb not receive all channels available? Other tv is fine. this one is an older model(free off of craigslist) and it won't get a bunch of channels. I have cable 2-57 in BC Canada. ANY...
I have a old RCA tv model F32632SB...and im having problems autoprogramming it...when I start the autopramming it starts on channel 14...after its done goingthru all the channels still no picture on all channels except channel 11...ive autoprogrammed the tv 50 million times still nothing... I tried the cable cord in another old tv and the cable is fine..anybody know ????
Nov 28, 2010 | Televison & Video
How do i get my wii to play on my RCA t.v, model number f32632sb?
did you try the inputs thats on the side? they r kinda hidden. mine r on the left side if you are looking at the tv. i connected my wii to my tv like that and now it cuts off all the time.. didnt start till i put the wii in but now it does it all the time.
Dec 27, 2009 | RCA F32632SB 32" TV
Can't get the tv set to video input mode
You may be able to press the channel down button, past channel 1 to the av inputs.
It works on some tvs, but not all.
Aug 27, 2009 | RCA F32632SB 32" TV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Hour Glass picture on a RCA TV F32632SB
I looked up this model and found the following electolytic capacitors to be the most likely culprits within the pincushion circuit. Check these first. The starred one is the one I have replaced in the past to resolve this.
C4851 10ufd 50V
C4853 10ufd 63V
C4854 2.2ufd 100V
C4855 2.2ufd 50V
* C4862 100ufd 25V
Good luck,
Dan
Jan 13, 2009 | RCA F32632SB 32" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
NEED CODE FOR RCA TV
I'm not sure what the exact code is but here's an alternative:
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH
button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Good Luck!
Bill
Nov 19, 2007 | Philips PM435S Remote Control
Scrolling Channels
You probably have a bad channel down switch on the TV. This is common if any kind of liquid spilled inside of the TV near the controls. The other possibility is just a stuck button on the control pad itself. Sometimes the plastic warps a bit causing to rub against the cabinet causing it to stick. Try moving the button and see if it has free movement.
Mar 13, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
121 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
