I plugged it into my computer and it powers on and stays on back lights
work great, but you see vertical lines all over and more appear when
you press the menu button but you cannot see the menu. also when you plug it in as a second monitor
and tell it to identify the pixels get brighter with what would be the
number 2. I was wondering could it possibly be that the video input
board is bad and not sending the proper signal to the LCD monitor,
possibly the processor chip? both DVI and VGA cable types give signal to the
monitor. The Inverter board only seems to go to the back lights so I
don't think that could be the problem. I also pulled all the boards up and
looked at both sides, no bad solder joints, no bloated caps, nothing
burned or discolored.
Comments:
Jan 15, 2009
- No nothing to do with video card this is all in the monitor, the monitor is 3 years old and belongs to the company, but if I can fix it, then it is money saved. this happens when you plug it into any computer not just one.
You can't always see where the solder is off .
Sounds like you need to purchase a new video card.
But before you do ,.. go into your control panel and reset everything in the display settings to original.
Advanced- DPI should be at 96 as default then check (drivers) roll back to original drivers (if you are running an ancient version of windows)
restart your cpu
If this doesnt werk ,... you have a bad monitor . ( hope you kept the reciept).
Comments:
Jan 16, 2009
- There is definately something fried on the inside.
(You could always take a picture and glue it to the screen and pretend that it works.)
I have no sound and the driver can't be found since x2 is out of business. Where else can I find...
(More)
I have no sound and the driver can't be found since x2 is out of business. Where else can I find drivers for my MG15E monitor?
i have a samsung 2253 22' lcd monitor,power light flashes,and screen stays black ,it trys to light...
(More)
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
My company just purchased a user a View-sonic VG1930WM monitor. The user complains that the monitor...
(More)
My company just purchased a user a View-sonic VG1930WM monitor. The user complains that the monitor goes into sleep mode. I checked all of her power options on her computer and they are set for the monitor to stay on. Is there a setting on the monitor itself that allows it to go into sleep mode?
