Question about Kirby Ultimate G Bagged Upright Vacuum
Belt burning My vacuum keeps burning the beater bar belt. I have replaced it 3 times in two months....help?
  • Anonymous Mar 15, 2014
    The beater bar for this vacuum won't work, both belts are fine. Why won't it spin?
  • 27 Answers
The beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Posted on Jun 15, 2007
Beater bar intermently stops turning
It's likely that the belt is just slipping. Remove the bar and clean all hair, threads and other debris it collects in the bristles and around the ends. Check the belt for wear of the rubber; it may have teeth on it unless they were worn off from slipping. In that case you need a new one but save the old one for it's model number to purchase on line.
May 28, 2015 | Vacuums
Tip
Burning rubber smell from your vacuum?
Drive belt is slipping.
Remover cover from the bottom of the power head or base if upright style. Usually just 2 to 4 screws.
You will see a belt (thick rubber band) connecting the beater bar (roller with brushes) to the motor. Remove the beater bar and belt. You do not need to remove the motor. The beater bar will be held by clamps and screws. Remove the screws and clamps and lift the beater bar directly up.
Take the belt to your local vacuum dealer (note make and model) and get a replacement.
Installation is the reverse of removal.
Note: you will find a lot of hair and junk twisted around the beater bar. Take the time now to cut it all off.
Hope this helped. Please rate this if it helped you.
on Mar 07, 2010 | Vacuums
Beater bar doesnt revolve
Hi, it's Allie from Crucial Vacuum!
There are a few potential solutions you should try. Start by checking your unit's brushroll and clear it of any tangled hair strands or debris that my be blocking the airway. You can carefully use a pair of scissors to do cut and remove anything that is tangled and may prevent the roller from running.
Your unit's brushroll is connected to the motor by belts. Over time, the belt's wear down and stretch out losing the grip and tension that turn the roller. Ideally, belts should be replaced every 3 to 6 months.
Follow by checking the internal hose for any blockages.
If the roller brush is still not working, the problem could be caused by a lack of suction. Washable filters should be washed frequently after every 1 or 2 uses or at least once a month, and replaced every 3 to 6 months for optimal performance. Non-washable filters, should be also replaced every 3 to 6 months to keep your unit running properly.
You can purchase direct your replacement filter and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 11, 2014 | Electrolux Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
It smells like it's burning when I vacum/what's wrong with it
Tammy May:
Unplug the machine and remove the foot plate (at the bottom of the vacuum head) and check the belt that drives the beater brush/bar. if the beater bar is hard to turn, pull the beater bar and belt out, check the inside circumference of the belt to see if the motor shaft has worn it down in one spot. If so, remove the two bearings (one at each end of the beater bar) and remove the hair, carpet fibers, strings and any other junk from the bearings and the ends of the beater bar. lubricate the bearings with oil (thin machine oil like 3 in 1 oil works best. roll the bearings with your hands until they spin freely. Now would be a good time to check the bottom of the foot plate where the dirt is vacuumed up. check the hole in the middle of the foot plate and check the hose for clogs if the hole and foot plate hole are clear, reassemble the bearings on the beater bar and install the beater bar (with a new belt) and reinstall the foot plate. The machine should run well for you.
Jan 19, 2013 | Eureka Vacuums
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Kirby Ultimate G Bagged Upright Vacuum Logo
243 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
