Question about Whirlpool AWM5145/2 Front Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
Hi my washer wont drain i have cleaned out 'empty' pipe also cleaned front 'drain' and emptied drum of clothes & water, but there is still water in bottom of machine and it wont empty out. it will spin & when i pulled it out water is dripping out of 'drain' pipe. pls can u help
  • weeboab Apr 11, 2009
    Machine will drain but only a dribble is coming out the waste pipe.
    I have checked the pipe that goes to the pump and that seems clear and if i blow into the pipe the water in the drum bubbles up so i think the pipe is clear upto the black rubber pipe from drum to pump.
    I feel the blockage could be from the drup to the pipe that gose to the pump.
    Does this sound right?
    Please help!!
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Posted on Jan 29, 2009
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
MAH8700AWW washer door wont open
hi adriana it is possible there is still water in the drum if that is the case the door wont open untill you empty it,this can be done by draining the water through the filter drain located at the front of the machine ,i hope this helps .
Dec 29, 2011 | Whirlpool LHW0050PQ Front Load Washer
Is there a lint filter I can clean in the Whirlpool Duet? I have water come up out of the drain pipe when it empties. I already put drain cleaner down the pipe but water still comes out sometimes. is there...
its your drain pipe thats blocked up,, i take it its the one that the washer is pushed into and go's out the wall to the drain that the water is coming back up from,,,in all sope powders there mostly made from a "clay base" so the out let pipe is blocked with "clay wast" push a cleaning rod down the outlet on the wall,,,down to the drain to clear it out its not likley to be the washer thats blocked up,
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
793 people viewed this question
Dan Webster
Dan Webster
Sal De
