Question about Solo Backpack Sprayer
Sprayer wont spray or hold pressure
Sprayer wont hold pressure to spray anything out
  • Anonymous Feb 05, 2009
    I have the exact same problem, sprayer wont hold any pressure to spray
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Posted on Mar 27, 2009
    New Friend:
After having the same problem,( no mention of this in manual),i sort help via internet. Someone had posted that a hammer and block of wood could be used, the 2x3 about a foot long is put through top of tank and on top of pressure cylinder.It does work, if you use a club hammer and the 3x2 oak, or similar! And the conviction to whack hard. Also helps if you block between underside of tank and the steel stand frame, reduces the bounce.Take care not to put block so small tube on underside of cylinder gets stopped.Good luck.
Posted on Aug 02, 2013
Won't seal and hold pressure
Try smearing some Vaseline on the gasket that goes around the pump shaft at the top.
Aug 06, 2011 | Ace Hardware Acer Spray and Go Sprayer
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
Won't hold air & pump up/
I loss pressure, read the manual, took the slide out and saw that the o-ring was crimped out of shape, thus the loss of seal and no pressure! Popped it back to position and it spray is now powerful as day 1...patience is rewarded!
Sep 21, 2010 | Gilmour & Spray Doc& Poly Tank Sprayer...
Ortho 2 gallon pressure sprayer has pressure but no spray
I had the same problem and had to take apart the handle portion and found that there was something in the line at that point. After cleaning it I had the same pressurse as when it was new.
Jun 05, 2010 | Ortho Chickweed Clover Killer Pint
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Windshield Water Spray
pull hose off sprayer and check for water pressure if pump is pumping water then jet is blocked use a small sowing needle in the jet to unblock jet dirty water blockes them get someone to hold the swich down while u do this wear saftey glasses when u do this u dont want dirt in your eyes
PLEASE RATE THIS HELP
Dec 16, 2008 | 2004 Acura MDX
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Solo Backpack Sprayer Logo
4,295 people viewed this question
Top Solo Garden Experts
Jim Parker
Jim Parker
Colin Stickland
Colin Stickland
Are you a Solo Garden Expert? Answer questions, earn points and help others
