Question about RCA F32665 32" TV
RCA F32665 Shows only gray screen, sound works.
RCA F32665 TV About 15 minutes ago, my screen turned an illuminated gray. Sound works, I can pull up menus and prompts, but regardless of whether the cable , dvd, or antennae feed are on or off, the screen shows gray. When I turn it off, it turns back to normal black. It will go thru and display the menu prompts, but does not show what is being feed into the tv. Help!
  • vinray89 Mar 04, 2008
    I too have just become a victim of this annoying problem, but of course the set is nearly 10 years old, and I only paid $40 for mine used a couple of years ago, so I guess I shouldn't complain, but I cannot afford to buy another TV right now! Besides, I just can't justify buying another standard definition set. I think I would not buy anything but an HD capable one at this stage in the game, and that will cost at least $500. If anyone has any suggestions on where I could find parts to fix this problem, or advice on exactly how to do it, please let me know ASAP. Thanks! (It sucks to be poor!)
    Novelist:
    Champion:
  • 236 Answers
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Posted on Jun 16, 2007
I'm having the same problem. It appears to be some sort of programming issue. Unplug the set for a few minutes, then go through the setup procedure when you plug it back in. This will work for a while, if anyone has a permanent solution please post it.
Posted on Aug 19, 2007
SOURCE:
My old 32 inch rca f32665 stopped working as we were watching it. no picture or sound and there is a sound coming from the back where the power cord goes in that sounds exactly like a cricket only its a...
The usual cause is a shorted horizontal output transistor. The way this chassis is designed, the supply makes 140 volts which is always on and applied to the transistor. The heavy load on the power supply causes it to make that chirping sound as it keeps trying to start, then shuts down right away.
The h-out is Q14401, RCA part number 237470. A 2SC5148 can replace it.
Jul 31, 2011 | RCA F32665 32" TV
32" RCA Entertainment Series, Guide
Probably not. RCA parts for this model are very difficult to find. Even you could find a kit, it will not have enough to repair. A do it yourselfer or TV tech will have a difficult time repairing this. Please shop for a new TV. Thanks for asking and show a few hands of support!
Mar 21, 2011 | RCA Televison & Video
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound to TV when MUTE button is turned off.
eeprom ic after you replace it you will have to have service menu to reset hori sink .
Dec 12, 2008 | RCA F32665 32" TV
Rca tv F32665
Try other inputs such as rca and svideo.
Aug 18, 2008 | RCA F32665 32" TV
NO SOUND
Unplug the power to the tv for couple of minutes; replug and should have sound!
Jul 19, 2008 | RCA F32665 32" TV
First of all its an rca opal M4002
press the reset button then press play
Oct 09, 2007 | RCA OPAL M4001 MP3 Player
RCA F32665 32" TV Logo
233 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
