Question about Intel Motherboard
2 beep sound on restart in asus motherboard
When start on asus motherboard 1beep+1beep sound total 2 beep sound no display
  • info_rwm Jan 14, 2009
    asus mother board model M2N68-AM -AMD
  • Jason Edinger May 11, 2010
    What is the computer make/model and what brand is the motherboard?
  • 135 Answers
Memory problem or graphics problem change them
Posted on Jan 18, 2009
My cpu is making 1long beep and 3 short beep sounds and not restarting.
This POST beep code usually means a RAM problem.
Try reseating your RAM module/s and reboot your computer.
Try the BIOS setting and check the RAM size, does it match the total installed RAM.
If you suspect the RAM is faulty, remove the RAM module/s and take it to your friendly computer repair shop and get them to test the RAM for you.
Jan 20, 2012 | ASUS M2N-MX SE Motherboard
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
1 beep 5beeps 1beep 1beep
Try remove the ram and clean the part and put it back ,.
Dec 02, 2009 | Intel Server Board SDS2 Motherboard
Computer won't restart....
it appears that this is a memory problem, based on the codes that you specified.
the reference for this is:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124996
Aug 09, 2009 | Computers & Internet
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
ASUS P5GL-MX is not showing display power button is pressed
Pls go through the steps given below...
1. Ensure that the 12 volt 4 pin connector is fixed correctly
2. If there any Beep sounds(Long beep=Memmory complaint)
3. Try replacing or re-installing RAM and HDD
4.Try with another SMPS (Display will not come if 3.3V,5V....missing)
Mar 01, 2009 | ASUS P5GL-MX Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
Problem with my computer after clean up
You may need to reset the bios by finding terminal 'JBAT1' and put jumper from pins 1-2 to pins 2-3 for a few seconds, then back to pins 1-2. Check the memory is seated correctly and graphics card if fitted. Ensure you have'nt put too much thermal compound on the processor, it only requires a very thin application. Rstart pc then set time and date in the bios setings and save ten exir for a restart.
Feb 12, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Intel Motherboard Logo
217 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
