Question about Ricoh Aficio 450 Copier
Ricoh 232c It is not doing anything. I cannot get it to go past " Please Wait" during initial start up. I have tried to go into the setup mode but the keyboard does not respond. I have tried holding doen the setup and clear buttons during power on/and off. unplugged it let sit, When it is turned on goes int statr up with "Please Wait" and then just locks up. No keys respond at al
  • Anonymous May 11, 2010
    I've not sen this model? Do you mean 2232C??
    If so, It sounds like a hard drive to me. and also, If so, I believe you can unplug it and the machine should boot up (if that is, in fact, the problem), there will be limited functionality, however, such as scanning, but this should isolate the problem
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are there any error codes at all?
  • 37 Answers
The problem is on your hard disk, it is malfunctioning or totally not working, you should replace the harddisk.
Posted on Feb 27, 2009
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
Hello..m fadhir i just bought samsung lcd tv 32" yesterday.. during initial setup/ plug & play, i suddently choose wrong language (taiwand/tahi) at the 1st step, then i cant understand anything...
hello,
To enter initial setup you can refer setup simbol with gear pict. On top menu of setup (gear) press enter again. Follow the instructions. Or you can read my post here. That the same way but for deferent problem. Good luck.
Mar 30, 2011 | Samsung LN-R408D 40 in. LCD HDTV
Ricoh Aficio 550/650 prints so light that you can barely see anything on copies. Have changed toner and have tried image density; nothing helps. Ideas
Verify TD sensor, you change the develop and Performs the TD sensor initial setting.
1) Press the following keys in sequence.
Total clear yellow key, 1 0 7 and
Hold the clear stop key (orange key) for more than 3 seconds, to enter at service mode.
Enter 2801 and execute...
This SP mode controls the voltage applied tothe TD sensor to make the TD sensoroutput about 2.5 V. After finishing this, theTD sensor output voltage is displayed. It must show a value near 10 Try use original toner.
If this does not solve the problem, replaces the cylinder, and perform id sensor.
Feb 24, 2010 | Ricoh Office Equipment & Supplies
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Richo 2232c
Make sure all the covers are closed on the copier. Check for any broken magnets, door switches, or sensors.
If that doesn't work you should contact a Ricoh representative in your area to do further troubleshooting tests on your equipment.
Jan 13, 2009 | Ricoh Aficio 2015 Copier
Dell Latitude D600 won't go past the Dell startup screen
Tap the f7 or f8 key, when you turn it on, it should go into safe mode, Go into start programs, accesories, tools, and restore, select restore, select a date closest to today and let it go through the restore pocess, if it suceeds and starts up, rub a good virus program right away, it sounds like you picked up a virus or trojen, just be patient and it shoul be ok, if it won't go into safe mode, let me know, that will require more work. And before you do anything, unplug, remove the battery for a few minutes and replace, try it and if it still won't run, do the above, thanks ,GYM
Dec 19, 2008 | Dell Latitude D600 Notebook
Ricoh Aficio 450 Copier Logo
233 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
