Question about Canon imageRUNNER C3220 Color Copier
Re:Minolta copier EP 2151 I am trying to print a stack of documents using SDH mode (semi-automatic document handling). The SDH mode green light comes on and blinks, but the light on the "go' (print) button stays dark. How do I get the copier to automatically feed the paper through- and make copies?
  • dwmetzgr May 11, 2010
    Make sure that you have no documents on the glass, open and close adf and press the reset button (usually a yellow key by the stop or print button). Then try to scan your docs through the adf.......
  • Canon Expert
  • 1,326 Answers
If the green light on the adf is blinking that means that there is a paper jam in the adf. I sure you know that the copier you are using is at least 10 - 15 years old. Has the adf worked recently? Are one of the adf hings broken? If so, line the adf straight on the top of the copy board glass. There is a magnet that needs to be closed to make the adf work. Try to see if there is any small piece of paper in the papeer path of the adf and use a can of air to blow out the sensors and get back to us.
Posted on Feb 11, 2009
How do i solve my minolta copier cspro ep 1054 printing blank document
check the transfer wire assy. located under the drum. might not have a good connection or the High Voltage unit is bad. That is a very old machine.
Apr 03, 2017 | Minolta Office Equipment & Supplies
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
I have a bizhub c252 it was working fine untill we moved to our new office now automatic dispenser is not working,error message say's original size cannot be detected
Check that the chord for the doc feed hasnt come out and that when you put document in the feeder the light comes on and it initialises the tray lift to the ready position it sounds as if the feeder connection is faulty and it is looking for document on the glass face to copy .. it doesnt see the document so it cant work the size out.
Feb 09, 2010 | Minolta Di3510f Bizhub Copier
NO LIGHT NO MOVEMENT INSIDE.
If there is no light coming from the lamp in the scanner and the carriage is not moving this is a serious problem. It could be that the main board is bad. Typically the exposure lamp is just burnt out but if the carriage is not moving something more serious is not working. Just to verify open the document feeder on top and press the start key. You should get an error code if the lamp does not work.
Jan 19, 2009 | Minolta DI-2010F Copier
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Canon imageRUNNER C3220 Color Copier Logo
150 people viewed this question
old marine
old marine
