Problems with sound that buzz/vibration sound My brand new Toshiba 40 LCD has similar occasional buzz/ vibration coming from inside TV
  • Anonymous Feb 25, 2009
    vibration sound coming from inside the tv when there is lots of music and speking that includes heavy bass. Mainly when watching films. 40" Toshiba aswell!!!!!!!!!! i wonder lol
  • Anonymous Feb 27, 2009
    Me Too! 40" Toshiba.
I returned my 40" a week after i bought it. I got a replacement which is actually worse. I had the Toshiba technician come out to repair my 2 day old telly. He went away scratching his head and was going to sort it out with Toshiba. If I get any joy, I will post the soloution.
Posted on Mar 04, 2010
  • conwan34 Apr 11, 2010
    Hi guys. Been a bit slack with a soloution. I had the tech come out. He opened the back, put some double sided sticky tape in there , tuned the sound so it sounded like a transistor radio and went away. It still vibrated a little. I tuned the sound so it sounds normal, and it is still annoying. I sent Toshiba a letter(as there is no email address anywhere) and to their credit, they rang me. I was told that they haven't heard of this problem before????? I was also told in a very polite and round about way that it's bad luck and I will have to live with it. Bit disappointing when you spend a little bit extra, but hey, that's life. Will research a lot more when I buy the big one for the rumpus room. Sorry that I didn't come good with a soloution , but I think that the only soloution is not to go with this particular brand.
Me too, check in the menu Video/Picture settings and press down backlight...
works for me.
Posted on Feb 25, 2010
Same problem with my new Toshiba 55" LCD.
Also, after being on for awhile, the sound suddenly gets distorted in a fuzzy, echoie kind of way. Switching to a non-digital channel and switching back seems to make that correct itself. I may try a new HDMI cable to see if the problem goes away. Any other ideas?
Posted on Dec 14, 2009
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
I have a Phillips Fla screen and a few days ago it started making this loud buzzing/hissing sound that somewhat goes away once the TV is on but comes back with a vengeance when we turn the TV back on i...
Most likely if a buzzing or similar sound that is there even with set off--you have a noise coming from a transformer in the standby power supply which is running all the time if the set is plugged in----
Someone would have to open set and listen for it---either a part, a board, or hot glue would have to be used to mute the vibration that is making the sound----one way we locate is with cover off probe with a plastic tool to see where it is.
If you are not able to do this have a tech or a shop "look" for it.
Dec 03, 2012 | Televison & Video
Toshiba flat screen problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 15, 2017 | Toshiba Televison & Video
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
My toshiba makes a buzzing noise when the colour
you will need a power board the laninat in the power transformer is vibrating causing your buzz wine
Nov 02, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
I recently purchased a 52 inch LCD. I have
This could be the speakers are vibrating onto the casing and need padding out more to prevent this.If this isnt the case, you may have a sticking coil on one of your speakers..When the sound distorts, remove one speaker in turn to see which one(s) are the offending unit(s) and replace. Is there a buzzing noise coming from the speakers especially in low volume? If so then you may have a faulty capacitor in your power supply producing hum on sound. Hope this helps :)
Oct 17, 2009 | Toshiba Televison & Video
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Bush 37inch HDMI
I've ran into this before and all that was wrong was the RCA hookups from my dvd player. The colors are very similar and I found it by unplugging one jack at a time and the buzz stopped when I found it.
Hope that's your only problem,
SkipofSaturn
Dec 17, 2007 | Philips 25PS40S 25" TV
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Televison & Video Logo
2,100 people viewed this question
Top Televison & Video Experts
