Question about Olevia LT32HVM 32 in. LCD Television
DVD Hook up-Olevia 266-T11
I am a novice when It comes to anything electrical, But I want to simply hook up my DVD player to my TV. I bought the converter box because the Olevia doesn't have a video in slot. Now I have a standard cable hooked up to the box that the DVD player is hooked into. Everything is in place, but why can't I see the DVD screen. I checked every source, and I had this TV and DVD player hooked up before I moved so I know it works. I just forgot how.
  • bekahsonrisa Jan 14, 2009
    There is not a Tv/Video button, only a source; ie Component, Tuner etc. The only thing that is showing up is "No Signal" on each of the sources.
  • 716 Answers
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Posted on Jan 14, 2009
  • Michael Fisher
    Michael Fisher Jan 14, 2009
    how do you have the unit hooked up?
Can not hook up my dvd to my new vizio tv
What is the brand name and model number to your DVD player?
Jun 07, 2012 | Toshiba Televison & Video
Can't hook the WII and the DVD player both up and the same time.
You can hook the Wii up with the standard RCA jacks and the DVD with the HDMI or vise verses. How many hook ups are on this TV. You can also run the Wii through the DVD using a aux channel on the DVD.
Dec 26, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
We are trying to play out playstation 3 on our Olevia 226-T11
be sure to check:
The tv is on the appropriate AV Channel ( the same one you plugged the ps3 cable into )
The cables are connected properly.
Or Your channel input settings might be wrong on your tele ,, so maybe, AV 2 is set to actually take signal from the AV 3 input...
Maybe wrong but just check these things cause sometimes its something stupid and you'll kick youself later ha ..Good luck
Jan 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
RC23 remote code for Olevia 226-T11 TV
Try these codes; 10178, 10856, 10054, 11454, 11447, 10047, 10030, 10019. One of these should do the Trick! Good Luck!
Feb 22, 2008 | Directv RC23 Remote Control
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Olevia LT32HVM 32 in. LCD Television Logo
655 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
