Question about LaCie Pocket Floppy (706018) External Floppy Drive
Lacie usb floppy drive won't format a disc
Using winxp sp2 on a dell 2100 an canot format the floppy disk using a lacie pocket drive lostor misplaced the install disk am i sol
  • 101 Answers
On the floppy disk there should be a little switch push it across
now put in right click options format
Posted on Aug 29, 2009
Format problem with Lacie portable HDD
Format the drive using another utility then delete the partitions on the drive and try again
Aug 17, 2012 | LaCie Rugged All-Terrain (301017) Hard...
Teac external floppy disc drive will not format floppy disc
U need an interface, if u want to use the "34 pin out" from floppy disk unit, to the "24 pin in" connector jack, inside KN 1000 main board.
U can get this interface unit bboard from "the KN 1000 floppy disk drive unit".
Just open this unit SY-FD20, and pick out that interface board from this unit,
Then use it as interface to connect your new 34 pin out floppy disk drive to connecting to the 24 pin in connector jack inside the KN 1000 mainboard.
Feb 06, 2011 | Teac IBM USB Portable Diskette Floppy...
Where is the insert for the floppy disc
The floppy disk may or may not be installed in section 5. They started eliminating floppy drives some years ago, when USB flash started to become popular.
5
FlexBay drive panel
Can contain an optional floppy drive or optional Media Card Reader. For information on using the Media Card Reader, see Using a Media Card Reader (Optional).
If your question was more basic than this, and you have a floppy drive, then you just insert the floppy into the slot. It doesn't open. Look for the arrow on the floppy disk, if it doesn't go in one way, turn it over.
Sep 13, 2009 | Dell Inspiron 531s Desktop Computer
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
LaCie Pocket Floppy (706018) External Floppy Drive Logo
314 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
