Question about Dell E153FP 15" LCD Monitor
Dell E196FPf monitor power problem
How to open dell e196fpf Monitor back cover with lock
  • 558 Answers
Generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Posted on Feb 17, 2009
Im having trouble hooking up my sound bar to my monitor E196FPf
As far as I know, the E196FPf monitor does not have speakers or an audio out. Thus you'll need to connect the sound bar to the audio out of your computer or other source. On a laptop, this will be the headphone jack. On desktops, you use the lime-green 3.5 mm jack on the back of the system.
Depending on the sound bar, you might need a Aux (3.5 mm M to 3.5 mm M) cable, a 3.5 mm M to dual RCA (red/white) adapter cable or an analog to digital audio converter with the 3.5mm to RCA cable and appropriate digital audio cable.
Please add a comment with the model of the sound bar and the audio/video source, if you want more information on the best solution for your application.
I hope this helps.
Aug 07, 2016 | Computers & Internet
Tip
How to open up / disassemble Dell E196FP Monitor
On my Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
on Nov 23, 2007 | Dell E196FP 19" LCD Monitor
Dell 19" LCD E196FPf monitor
Yes,
http://s807.photobucket.com/albums/yy352/budm/Dell%20%20E196FP%20Rev%20A03/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Feb 26, 2011 | Dell E196FP 19" LCD Monitor
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Dell E196FPf lcd
On the back side unscrew everything you can unscrew, then using flat screwdriver with 1/4" wide blade try to disconnect halves of plastic case, there are plastic fixers over the edges, inside, so try to not brake them all :)
Next, you will need to unscrew metal cover inside to get access to the PCBs. If monitor was killed by surge, most likely you will see what is fried there. Check fuse on the PCB.
Sep 14, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
DELL E173Fpb
On my similar Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
Nov 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Opening case
My power button broke free and in case you're still trying, I was just successful with this hint on my 19" version of this monitor. I used two small screwdrivers, and with the monitor face-down on a pillow, I started with the left notch (near the kensington lock hole). The secret trick was to pry the notch with the first screw driver, hold it with my right hand, then take the second screwdriver and push in just to the left of that gap, and the first "catching-mechanism" popped free, releasing the whole corner. Continue working your way around, but pushing in to release the next catches, not so much twisting (less tearing up your monitor that way, too) - four across the top and bottom, three along the edges. Unfortunately, I do not have a way to post pictures.
Sep 21, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E153FP 15" LCD Monitor Logo
763 people viewed this question
Alun Cox
