Question about Panasonic SC-HT690 System
Tray not opening
My Tray does not open. Tried to switch off power and restart. There is a motor noise but it does not seem to open.
My RCA vcr/dvd player did the same exact thing. I opened it up and tried it again with the cover off----it worked perfectly. Seems as thought the cover might have been pressing on the inside unit top and possibly binding the slide movement. There is a bearing assembly there that might be involved. I reassembled the cover and had a partial recurrence of the problem. Then, as I punched the open button I slapped the case sharply on top, and the side came out. You might open yours and see if there is anything physically causing some mild binding Good Luck!!
Posted on Jul 30, 2007
  • irby hartley Jul 30, 2007
    The word "side" should have been "slide.
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
B&O DVD1 PLAYER DOES NOT OPEN ON DEPRESSING EJECT. NO DVD IN IN THE PLAYER. CONNECTED TO B&O BEOVISION. HAVE TRIED DISCONNECTING POWER. ANY SUGGESTIONS?
if disconnecting power does not help then you will have to open the player and make the DVD tray roll out.
Aug 05, 2008 | Televison & Video
Combo dvd vcr tray won't open
The belts are under the VCR tray and under the Disk tray.
Feb 15, 2010 | Panasonic Televison & Video
DVD player will not open
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
Dec 14, 2009 | Toshiba SD-K860 DVD Player
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Tray will not stop opening and closing
You have to open the cabinet ..with the power off!! with tray open look at the laser it should be in the cd home position..move the laser toward away from the spindle motor or turntable.you should see a switch with a cover over it,it may be black or white or clear..the is your laser home switch..with your finger or small screw driver gentely push the switch towards you or bend it towards you.with the cover off.plug the unit up.Watch the laser as it moves away from you towards the cd spindle, it it stops and the tray moves in, and the cd mech chucks .you should see the laser turn on and see the objective lens move up and down..if it does not..and it continues with your original problem the you have to retime the tray and loading gear..try this first..
Nov 02, 2008 | Sony CDP-CE335 5-Disc CD Changer
Dvd tray won't open
Don't take the cover off. Open the door and use a small flat instrument to depress the tray release buttom (it is indented on the lower right hand side of the tray. If there is a disk remove it. Turn off your system and the tray will close. Restart you system and see will the trat open.
Jul 15, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Pioneer DVL-909 DVD Player
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Panasonic SC-HT690 System Logo
63 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
