I need the remote control code of KONKA tv model K2979A3
My origenal remote control got dameged for KONKA tv model K2979A3 and i purchased PHILIPS universal remote control model SRU 5060 , so i tried to mach the code of the tv and universal remote contol but i was not able to mach thim.
Note: I have used both the PHILIPS code and manual search but there was no benefit
SOURCE: searching for TV remote control code for PLTV-32
I spoke with their tech support in India and was told this tv will not work with a universal remote.
Posted on Dec 30, 2007
  • 10 Answers
SOURCE: need code for universal remote
I need to know what model the Unversal remote is. if it take a 4 digit code, you can try these:  0054, 0030, 0171, 0020, 0096
Posted on Feb 09, 2009
SOURCE: Need the remote contol code for AOC L26W861 Lcd TV
Just kept repeating the U-Vesre procedure over and over and Wham! Persistance was the key.
THX
Posted on Jun 12, 2009
BElectric
  • 1140 Answers
SOURCE: Our remote control locked somehow
The remote may be faulty rather than locked. It could also be a faulty Infra-red (IR) receiver in the TV. There are some simple checks you can do to establish the cause of the fault.
First, try this trick for unfreezing a 'dead' remote:
1. Remove the batteries.
2. Press and release every button on the remote one at a time until every button has been pressed and released at least once.
If your remote has any slide switches, you must repeat the button pushing for each switch position. When you've pushed all the buttons, put the slide switch back in the correct position to operate the device you use it for.
3. Put the batteries back in the remote, and make sure they are correctly installed. Use new batteries if you're unsure about the old ones.
4. Try the remote.
If this doesn't work, check the remote is sending a signal. Take it into a darkened room and look into the end which you point at the TV/VCR, etc. Press a few buttons and make sure you can see the red LED flashing. Alternatively, get someone to point the remote at you and press some buttons while you look at it through the viewfinder of any digital camera or an analogue (tape) video camera - a mobile phone will be fine for this. You should see the flashes clearly.
If you can see the flashes, try replacing the batteries and try with the TV again. If it still doesn't work, it's likely that the IR receiver in your TV (or whichever device you are using it with) has failed.
If you can't see any flashes after doing all of the above, then your remote is probably dead and the easiest thing to do is replace it as repairing it will cost almost as much (or more) than buying a new one.
Hope this helps.
Regards,
BElectric
Posted on Nov 25, 2010
gopakumarg43
  • 74617 Answers
SOURCE: Konka TV Model K2173PM.
Hello
Just buy one Philips Universal Remote control model number [CL 034]. Konka is listed on its codes. Codes and proceedings are given here.
Codes
............ 0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Posted on Jan 27, 2011
Universal tv remote control code for konka KK-Y26IN
Hi, this Konka remote is not a universal remote and cannot be programmed to any devices. It only works with the original Konka TV. To purchase a new Konka remote for you Konka TV you can go to Replacement Remotes.
Oct 06, 2012 | Universal Remote Control Remote Control
I need to purchase a new remote for my Konka TV model KDL32FS62U. The remote I'm replacing due to damage is a KK-Y319A. Any idea where I can find a replacement remote?
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Find out codes for Konka from the code list provided by this site. Pull up older posts there. Buy one universal remote control, which has setup codes for Konka described above. all setup proceedings also described.
May 14, 2012 | Televison & Video
Konka TV Model K2173PM. I have tried to find a replacement remote control for the aforementioned TV. However, to no avail. Many universal units say available for Konka, but none of the codes seem to...
Hello
Codes
Direct Code Entry
button.
flashes.
OK.
Jan 27, 2011 | Konka Televison & Video
I like to bye a romote control for K2979 tv where can I get one ?
hi,
better u purchase an universal remote, and program it for ur tv.philips magnavox universal remote can be used to control ur tv by entering any one of the following code
KONKA .............. 203 ,208, 219, 306, 317 ,417
ok
Dec 15, 2010 | Konka Televison & Video
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
No Konka TV Codes on Uni. Remotes
Hey everyone if you are trying to find the code for your konka tv on philips universal remote it is : 0208. My fiancee just played around with codes and figured this out. so your code is 0208..
Good Luck!!
Sep 10, 2008 | Konka FL2792U 27" TV
Konka
I don' t have the code for TV KonKa model k 2386 U and my remote control no working
I have one universal remote Atak RA 10, but it don't have the code for konka TV.
Mar 16, 2008 | Konka K2386U 23" TV
Help me
Try www.replacementremotes.com Their website says they have a replacement for your original remote model # KKY223 with a model # KKY223A. Call to verify availability. Other sites I have checked state that neither of these is available anymore. In addition, you may want to consider purchasing a generic or universal remote for every day usage to save the factory unit from the day-to-day abuse that all remotes suffer.
If you go shopping for a universal remote, be sure to verify that it specifies that it will work with your particular Konka model. There are a # of people writing to this site looking for remote codes because they didn't verify that the universal remote they purchased would work with their TV.
Feb 25, 2008 | Konka FL2792U 27" TV
Code for a toshiba Tv
Have a 2006 Konka 15' LCD, model # 1508U, which cannot be programed to work on Verizon remote. I need the code so Verizon can put it in.
Dec 19, 2007 | Philips PH-BIG3 Remote Control
Konka code
I have small TV called Konka for my small kid.This TV was bought in 2000.My problem is that kids have damaged the remote control of this TV now to operate it I need Unversal Remote control. Konka tv is never found on any of the manual of unversal remote control lists.
So, is it possible to get CODES for that Tv.
thanks
Sep 07, 2007 | Konka K1938U 19" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
