Question about Brother IntelliFax-2820 Laser Fax
Printing quality problem
I have a Brother Intellifax 2800 that I sometimes use to make copies. Lately, the image quality deterioratyes after the 6th page in that each successive page has larger and larger areas of black clustered streaks. My toner cartridge is reading low, but I would assume each page should get lighter??? In addition, when many copies are being made, there is a burnt aroma from the fax machine and the printed pages are warm. Is it time for an image drum replacement? I cannot find this situation in my manual. Walter Sawicki
    Champion:
  • 320 Answers
HELLO! IF YOU ARE USING A GENERIC DRUM OR TONER, YOU WILL HAVE COPY QUALITY PROBLEMS
Posted on Jan 15, 2009
How to reset brother 2850 fax drum
Try opening the front and press clear it should say replace drum press 1 for yes it should then reset,
Oct 15, 2009 | Brother IntelliFAX 2800 Laser Fax
We had a paper jam and I got the paper out but now the fax machine is printing out pages that are smeared with black toner
The fusing unit heat roller is damaged or worn out and it needs to be replaced.The roller has non-sticking teflon coating.When this coating is bad,toner start sticking to it and causing jams and bad copy quality.
Sep 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Horizontal lines and tones specks around text
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
Jun 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Faxing copies of drivers' licneces result in poor quality
The Brother 2800 is pretty good machine within its limitations.I would suggest if possible to copy the drivers license on a regular copier and both lighten it up and enlarge it.I had good results using this procedure when I had to fax Licenses.Good Luck
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Fax Confirmations
1) Menu/set
2) 2
3) 4
4) 1
5) Press + or - "ON" or "ON+ IMAGE" to have confirmation with a preview image of the first oage you sent
6) Menu/Set
May 01, 2008 | Brother IntelliFAX 2800 Laser Fax
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Problem with printing...
First and most important with Brother machines is , you need to use genuine brother supplies. Almost every time I service a brother and I find generic toner and drums cause the print quality issues. New supplies cost as much as a new machine. If not the supplies then it is laser or power supply.
Aug 06, 2007 | Brother IntelliFAX 2800 Laser Fax
Incoming fax quality
Are you using genuine Brother supplies? Generic supplies are the main reason for print quality issues. Have you ever changed thr drum unit ? Expensive! You can buy a new machine and get a new drum and toner for a little bit more.
Oct 22, 2006 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
203 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
