Question about Gateway FPD2275W LCD Monitor
Need to Unlock Monitor
The menu along side of the monitor says that it is "locked" How do I unlock it?
  • elrod7 Jan 29, 2009
    my screen is off center so i need get to monitor menu but it is locked. how do i unlock it. menu "buttons" are on front.
  • 558 Answers
Typically there is a cable on the back this needs to be released with a special key, this is typical in a business environment and should not be in a home monitor.
Let me know how it turns out.
Posted on Mar 22, 2009
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
Aug 27, 2014 | Dell P2210 Monitor
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Getaway monitor is on menu locked. how do I unlock
just ask to getaway monitor
for this problem
Oct 22, 2009 | Computers & Internet
Monitor Controls Locked
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
Apr 30, 2009 | SAMTRON 77V 17" CRT Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Osd main controls locked
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
