Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
I have a problem with my hotpoint fdw60 dishwasher. The door won'
Think the catch is broken, is it difficult to repair or do I need an engineer?
ta, Alan
  • zero-waste Jan 21, 2009
    I had to remove the back panel off the door to get inside.
    The connections to the sensor were a little tight - but some wiggling freed them. The door was difficult to reassemble, so an extra pair of hands to keep things lined up helped. The replacement part P24 - B50 for the Aquanaut FDW60 cost about £10 from a local supplier in the yellow pages. Hotpoint wanted to charge us £100 minimum to send an engineer around, as we were outside warranty. One less defunct hotpoint littering the planet! One less unit of unnecessary consumption!
  • 979 Answers
I think you can fix this yourself if you can see the latch itself. There should be some screws at or near the latch that can be removed. this would allow you to physically get to the latch and check it out. It may be that the latch is broken or loose OR it may be where the latches "catches" that could be the problem also. You are probably looking at an hour's work.
Posted on Jan 14, 2009
Hotpoint FDW60 DishwasherTablet does not dissolve
our HOTPOINT FDW60 is not working right?
the tablet is not disolving inside right how will i fix it?
Feb 07, 2013 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Help my Hotpoint FDW70 iS FLASHING a99...............Many thanks Sarah.
A99 is a communication error. Try unplugging your dishwasher for 10 minutes and then try it again. If you still get an A 99 code that suggests a problem in the control board in the dishwasher. In this instance I recommend an engineer as it can be extremely difficult to fault find this error.
Hope this helps.
Mar 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My door doesn't seal/catch when closing. Machine
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Apr 29, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Door not clicking shut
I had the same problem. There is a spring on the catch mechanism that breaks. Replace this and it fiexes the fault.
Jan 12, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Door won't shut Hotpoint FDW60
It maybe installed to high and if you lower the legs to lower the D/W you should be able to see that it will fix your problem.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
354 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
