Question about Sharper Image Ionic Breeze 3.0 Air Purifier
No indication that the unit is on ,no lights are on
The Ionic Breezs Pro GP just quit working . Is there any kind of fuse or circuit overload switch some where in the unit . If so ,draw a diagram of what/where might be the pb. area.
  • 2 more comments
  • richard_l_br Jan 15, 2009
    No advice on my 3year old Ionic Breeze Pro GP has been given. Waiting for some recommendations.
  • richard_l_br Jan 22, 2009
    Ionic Breeze unit is a Model S1830 which a PRO-GP type machine. There is no fan in the device. What info can you provide on the electrical schematic of this unit ? No lites are on . No responce to the control knobs. It is 3 years old.
  • richard_l_br Jan 23, 2009
    Ask Mohammed387 this--Does the moon rise in the morning or late at nite ?
  • richard_l_br Jan 25, 2009
    Can anyone tell me information on the electrical system for the Ionic Breeze ModelS1830
    Sergeant:
    Champion:
  • 435 Answers
Hi, the problem may not be the fuse. This linke might be of help. http://www.fixya.com/support/t227062-ionic_breeze_gp_s1730
Posted on Jan 25, 2009
    President:
  • 1,952 Answers
Ionic breeze" air purifiers use electric devices for moving ambient air; however, such devices are not known to have been applied to space propulsion systems nor has their use been suggested for use in the sparse atmosphere of the near-Earthspace environment. Toy devices, known as "lifters," use a tethered ion breeze device for lifting a light frame from the ground. Lifters have not been found to be practical for any significant transportation purpose, because they require substantiallyhigh voltage (e.g., >15 kV) for operation. Moreover, the ionic breeze devices being implemented in air purifiers, as well as toy lifters, rely on the relatively dense atmosphere found near Earth's surface; and they have not been suggested nordemonstrated for operation in the sparse atmosphere of the near-Earth space environment (i.e., in the altitude range of at least 200 km above Earth's mean surface). Although some recent experimental work has been performed using ion breeze engines forendo-atmospheric ion propulsion, such work has been shown to require a magneto-hydrodynamic slipstream acceleration for hypersonic flight to at least orbital velocities at the top of the atmosphere.
Posted on Jan 22, 2009
    Genius:
  • 1,011 Answers
Dear,
The problem is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
regards,
Posted on Jan 15, 2009
  • SALMAN NASEER Jan 15, 2009
    dear,
    there's another issue
    The rear grill has an electrical contact on it. If the grill is not seated properly, electrical contact is lost and the unit will not run.
    Here's how to remove and reseat the rear grill:
    1. Turn off the unit.
    2. Unplug the unit.
    3. Remove the collection grid.
    4. At the bottom of the rear grill is a blue tab. Pull it toward you and lift the grill up and off.
    6. Put the grill back on so that the locking tabs go into their slots.
    5. Slide the grill down to lock the
    regards,
    Brigadier General:
  • 8,619 Answers
Hi!
The problem is with the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
It appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
  • Rylee Smith
    Rylee Smith Jan 15, 2009
    I think the link below describes the switch, might prove somewhat useful if you want to repair it yourself
    http://www.dicgroup.com/pdf/SM/SM5-01N.p...
    Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
    Find a replacement part to fix it.
  • Rylee Smith
    Ask for any further clarifications...
  • 716 Answers
Do Any Lights Or Anything Come On? There Is A Good Chance The Fan Motor Has Seized If Your Out Of Warranty Take It Apart And Grease The Fan With Ball Bearing Grease. Do Not Use Wd-40
  • Michael Fisher
    Michael Fisher Jan 23, 2009
    I Am Currently Awaiting An E-mail From A Ionic Breeze Repair Center For The Schematic. I Will Tell You This A Lot Of People Were Having Trouble With The Switch So If You Can Try And Replace It. You Dont Have To Use The Same Switch Just Try Bypassing It If You Can To Test If Thats The Problem.
  • Michael Fisher
    Michael Fisher Jan 25, 2009
    Hey I Wrote An Air Purifier Company For A Schematic And Heres What They Replied?
    No unfortunately we
    do not have a schematic to give or sell for the Ionic Breeze or any of
    the Sharper Image units. They have been fully discontinued and can no
    longer be serviced or have parts sold for them, as they are currently
    being investigated by the EPA and FDA for safety hazard concerns. At
    this point, the only options for any customer with any type air
    purifier with Sharper images is to either consider a trade in program
    with another make and model from a different manufacture or unfortunately considering the disposal of that unit. WE do apologize
    and wish we could assist you further but they are handing out fines for
    any parts or services sold for any of these units so we can not take a
    chance. If you would like to speak to us regarding a trade in
    program to another make and model purifier we do have a brand new
    Lighting Air Plus unit that is currently on 50% off sale and is only
    $349.00!! With your discontinued unit as trade in credit we can offer
    you an additional $80.00 off that price! IF you are interested you may
    contact us at:
    800)705-7071 9-5pm M-Fr PST
    Thank you for contacting us, Air Purifier Repair
  • 837 Answers
How old is the unit?
  • 679 Answers
First tell me did you check out the battery? or not....
  • 1 more comment
  • rockfixya
    rockfixya Jan 15, 2009
    there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch, thanks jim.
  • rockfixya
    there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
  • rockfixya
    rockfixya Jan 16, 2009
    did any solution works for the problem?
    Thanks
Ionic breeze gp
cheak main power unit see if u can get one from radio shack start there do u leave it on 24 7 fan puts on a heavey load on power trasformers blows them easy
Feb 05, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
I need 2 new UV-C Germicidal Lamps for GP and GP Pro.
Hi.
Both Ionic Breeze purifier and replacement parts had been retired from the market because of health concerns related to ionic technology. Parts are sometimes available on ebay, but I suggest not carrying any repair on this unit.
Please read the brief article that I wrote here: http://www.fixya.com/support/r5303535-ionic_breeze_parts_repair
Sep 13, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
I have a professional series ionic breeze gp. It stopped working and has a red light on-something I had never seen before. Can you help with this model?
Well there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch. also check the fuse.
Good Luck!!
Thanks
Sep 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
No power.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Ionic breeze gp s1730
Ionic breeze gp s1730 I had the same issue. There are two switches in this unit. One closes if the back cover is on, the other closes when the removeable grid is in. My problem was with the later. Mine had corroded wire ends where it is soldered to the small circuit board where the switch is attached to. It also had a bad switch that did not close the circuit and I suspect internal corrosion as well.
Unplug the unit and remove the grid.
Remove the 4 small phillps screws from the front grill, remove front grill.
Remove 2 selector whells from top, remove four screws.
Test the switch function with ohm meter
Oct 20, 2007 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
