Question about Whirlpool GY396 Electric Kitchen Range
Whirlpool GY396 Oven not working at all
Unit is only 3 years old. I had a technician come out and he said that the control panel needed replacing. We replaced the control panel and it did not fix the problem. All the buttons on the panel work except those relating to the oven
  • Anonymous Mar 30, 2014
    Unit isn't working and oven lightbis still on
  • 4 Answers
Call him back out. Bad panel. It happens!
Posted on Mar 12, 2009
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
Mds-6 keypad
Some or many units make use of Tactile switches in the control panel of their units.. These become intermittent and noisy after a time. They need to be replaced. You volume issue may be caused by that type of problem in that the one press of a dirty switch might be sending several pulses to the processor signaling many presses. This is what I suspect- it is due to have the switches replaced afer 10 years but the unit will need to come apart and new switches obtained. DigiKey Electronics most likely has new ones of the types you will need. This is a job for a Technician who is able to remove and replace Tact switches in a PCB.
May 12, 2012 | Audio Players & Recorders
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
Whirlpool WFW9400SZ01 F71 flashing
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
F71 error - no other keys work - Duet Steam Washer
Aug 31, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Heating not working
There could be a number of other potential causes.
1-Ignitor failure
2-vent blockage
3-tripped rollout safety switch
4- tripped limit control
Etc...
Look at the door of the unit for a explaination of the number of flashes of the light. This may get you started in the right direction.
Jan 10, 2009 | Goodman GMS90703BXA Heater
Tub spins too fast on all cylces
Just wondering: did the technician also replace the motor control unit? Or is that the 'spin unit' that you mentioned?
See pages 4-7 and 5-4 in the repair manual.
http://adcxns1.whirlpool.com/Service...0Job%20Aid.pdf
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Whirlpool GY396 Electric Kitchen Range Logo
208 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
