I am troubleshooting a goodman package unit
All the wires on the schematic are in correct places, but everytime i try to plug in the 220v cord it pops the 3amp fuse on the control board?
also the model # and serial# are scratched off
  • 334 Answers
You have a short to ground somewhere in the low voltage wiring.
You will need an OHM meter to test each 24V component for continuity to ground.
Test each part with the wires disconnected. If all the parts are OK, then it is a wire touching somewhere. (unlikely but pssible)
I would start testing at the 24V side of the transformer. Often times it is the boad that has shorted internally.
Sometimes you can look at the back of the board and see burn marks where one circuit has shorted to another.
Contactor and relay coils are also known foir this problem. (24 V coils power the relay, sending high voltage to its corresponding component.)
Posted on Jan 14, 2009
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
Need instructions for gmp 32000s
Call Goodman, they send their heaters with big instruction bundles inside, and I'm sure they'd be able to sell you a package. If not, ask a supplier (simply because they have the leverage over goodman to make demands).
If you're looking for troubleshooting, on the inside of one of the doors is a wiring diagram and often a troubleshooting guide.
Oct 18, 2011 | Goodman GMS90703BXA Heater
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Need wiring schematic for a goodman 4ton unit model #mle48-1b
There should be one packaged with the unit. Shut off the power and open the metal enclosure around the control board.
--W/D--
Aug 18, 2009 | Goodman Heating & Cooling
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
305 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
