Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator side freezing
Two days ago everything on the top shelf was frozen. I cleaned the coils and turned the temp all the way down. It didn't seem to help. I noticed that we didn't seem to be getting any new ice either, but the freezer temp seemed right. Today, the fridge had water every where. It seems to be leaking from the PureSource 2 water filter. I am thinking that there is a block somewhere in the ice maker and the water and ice backed up into the fridge. Is this possible? If so, how do I clear the line? Thanks for any help!
  • 878 Answers
Kjn, I think what happened here is that the automatic damper assy. is stuck in the open position. This is why everything froze in the refer area. This includes the water filter and cartridge. I would unscrew the filter cover and see if it's frozen in there. If you find the filter frozen, take a hair dryer and go over it lightly until it will unscrew. After that you will have to check to see if the damper is stuck. You should be able to hear it open and close by turning the control on and off. Or get a mirror and hold it at an angle in back to see the gates. Part number for the damper motor is 240440701. Not that hard of a job...Catriver.
Posted on Jun 16, 2007
Water Filter Frozen
Air blowing directly on things like a water bottle has frozen it solid ( in the REFRIGERATOR SIDE! -- Block airflow BUT... I think the problem is YOU NEED TO CLEAN ( blow out with air!...the ONLY WAY) YOUR CONDENSOR COILS ( in the back, outside...behind the cardboard cover nowadays) Your fan has to run too long ( because refrigeration is the "removal of heat"...this is what those coils do but they are insulated with dust!)...too long blowing to achieve the same temp result = Frozen Stuff
Sep 24, 2017 | Frigidaire Refrigerators
Items freeze on top shelf of refrigerator. All temps are per factory specs.
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Nov 05, 2012 | Whirlpool GSC25C4Ey Side by Side...
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . hope this helps feed back pls
Jan 19, 2011 | Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My fridge side out the blue is freezing. All
I had the same problem with mine a few years ago. After two thermostat replacements and still having the problem, the third technician out explained that if you blocked the vent on the inside of the refrigerator, (the shelf below meat drawer,left side) it could cause freeze up. Sure enough, haven't had a problem since.
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Freezer quit freezing. temp now 41 fan blowing, coils clean,
Your defrost system is probably out. It's probably frozen up. Check your heater first, then the t-stat and timer. You will want to let the unit thaw out completely for a full day before replacing these parts. We have parts that we can ship to you. Hope this helps! Ella :>)
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Kitchenaid refrigerator/freezer
May 21, 2007 | Whirlpool GD5SHAX Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
305 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
