Question about Cambridge Soundworks 88CD CD Player
10-year-old Kloss, model 88 stopped playing, suddenly.
Above sums it; stopped playing in middle of a song. Checked plug, and tried it in other outlets; to no avail. Until this, had good sound, low static and good pick-up, both AM/FM stations. (FM stronger, of course, as with all radios.) Am wondering if it has a fuse or something similar that may have gone bad? I like the shape and size, in addition to the quality sound of this radio, but would not want to spend huge amt. on it. I have a similar problem with my Model 88 radio to the one betlea posted under the Tivoli model One. I use it to play my iPod in the kitchen - very important. The problem seems to be with the volume controller. Sometimes it plays fine and other times it just won't play at all.
Key symptom is that when I turn it on, the volume level display runs up to whatever the last level was, e.g. 35, then there is no sound. Sometimes if I turn it on and off several times, it will suddenly work again. Second symptom is that the volume level won't change, either with the push-button controls on the radio or with the remote.
Does anyone have a schematic diagram for the Model 88?
Thanks.
jallee
  • Backfire142 Apr 15, 2009
    my model 88 radio has been a POS since I bought it. Sent it back less than 6 months after I got it. It will play for about 1/2-1 hour then volume starts to fade. It picks up static from any other tv , etc. Choice was Bose or Cambridge. Too bad I didn't pay twice as much for the better product, good example of you get what you pay for!
  • 85 Answers
Sounds like a cold dry joint connection problem internally ,needs to be serviced
Posted on Jan 15, 2009
Henry Kloss Model 88CD cd player skips. how to fix?
The laser assembly moves from the inside of the disk to the outside as it plays. You can try to clean the rails that the assembly moves on. If there is something stuck to it, it can cause the laser to have a hard time moving and cause skipping. try cleaning with cotton swab and isopropyl alcohol.
Dec 31, 2017 | The Audio Players & Recorders
Hs 200 harman kardon stop working
Check the capasitors in the power supply. These often have a popped top surface, not flat like normal. These need to be changed. It can be as many as 10-15 bad ones.
Feb 14, 2015 | Harman Kardon HS 200 Theater System
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi. I have a Sansa Clip 2GB that is just about 1 year old and has always played perfectly. Suddenly it is playing back songs with a weird warped sound. Battery is fully charged and the warped sound is...
your headphone jack mitebe dirty or broken. try to clean out the headphone jack with a q-tip that has some rubbing alcohal on it and clean it out. if its broken then you mite need to replace it. if hats the case its best to try to get a new one those things are h311 to replace. but if your determined to keep that one then you mite be able to find another one that will fit the motherboard. find sum one who can solder good (if your not good at it) and get it replaced.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
My MP3 Player suddenly shuts off by its self. It only does this on the 'menus' if i browse through them for more then about 10 seconds, but when actually playing a song it's fine. Though, when flipping...
First thing I would do is download and install a software update program from rca's website.
If the upgrade doesn't work, which it should, then battery pack or ribbon connection cable between battery pack and main circuit board is loose or faulty.
Nov 12, 2009 | RCA M4204 MP3 Player
My uncles mp3 only plays 10 seconds of a song each time it plays
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
Sep 12, 2009 | GPX ML648B MP3 Player
Philips mp3 player SA 4010
my sana freezes when it first turns one
Jun 12, 2008 | Philips SA4010 MP3 Player
The walkman malfunctioned!!! please help!!!
Hi there, one of the problems you have is that there is not much you can access from via your phone, so often the easiest (although not speediest) solution is to re-upload the songs. Have you tried adding another song, playing it, and seeing if that song will play successfully? If it does, then I would suggest deleting the other songs, and uploading them to your phone again. If this is not possible (because you downloaded them straight from mobile network), upload them to a PC and see if the songs will play - if they do, save them to PC, reformat your card (my computer -> right click on card name -> format) and then put them back on your phone. Unfortunately if they wont play on PC either, the chances are they have been corrupted and you may have to contact your download source for a refund or new copies. If after trying these options you are still stuck, try a) a mates memory card in your phone, and b) your memory card in a mates phone. If a works and b doesnt, contact your memory card supplier. If b works and a doesnt, then contact your phone manufacturer. Hope this helps and isnt too confusing - Chris.
Aug 23, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Cambridge Soundworks 88CD CD Player Logo
2,369 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
