This may not be your exact mainboard part number but if not you can search for it. Just pull main board out and send it in here for repairhttp://www.electronresort.com/repair-ser...This may not be your exact mainboard part number but if not you can search for it. Just pull main board out and send it in here for repair http://www.electronresort.com/repair-service-c-144/westinghouse-553yv01011g-main-board-repair-service-p-5301.html
There is a defective electrolytic capacitor (470MF/16V) on the main board that went bad, it will causes intermittent, slow, or not power up, the location number of the cap is not marked on the board, please see the attached photo to locate it.
hi look at the back of the tv, to see if you can see a light, if so the inverter is working, if you can't you will need a tech to test the tv's power supply, for voltages, you need 24 volts going to the inverter hope it helps
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
Can a person just purchase the bad capacitor? If so, where?
