Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool Refrig. #ED5FHAXV - Ice Maker Stopped Working
FREE ADVISE and I didn't asked for an immediate answer and this is my question. After removing from freezer, cycle appears to not be completed. Ice ejector was pointing straight down in tray with small amount of frozen ice. Please advise how to check with volt/ohm meter or jumper wires. Could it be the motor? There were not any ohms reading between the two leds coming out of the motor. The status beam light seemed to be working properly, blinks with flapper door open and constant with it closed. Are parts available for ice maker #2198597 if it is the motor?
  • Don Longhofer Jan 21, 2009
    We tried everything that you suggested and had to order
    a new ice maker. Thanks.
  • 318 Answers
You have a broken cam inside the ice maker module. it happens when the ice maker cant get enough water to completely fill the mold. you need to replace the i/m module with part #W10190935 about 75-100 bucks. also you might want to replace the water filter.
Posted on Jan 15, 2009
Ice maker stopped dispensing ice.
Did ice maker stop making ice? Or the dispenser is not dispensing the ice? Is the correct model number ED5FHAXV? Sea Breeze
Mar 09, 2013 | Whirlpool ED5FHAXV (253 cu ft) Side by...
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
I have the Whirlpool ED5FHAXV side-by-side refrigerator. It has stopped dispensing water but the ice maker is still producing ice (very odd as they are from the same supply). Even though I was 99% it...
Same supply from your house and the the water valve on the refrigerator splits the supply. It could be the ice maker, the freezer getting warmer and not reaching the cold point for the ice maker to make ice or the a faulty water valve
Dec 23, 2017 | Refrigerators
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flashing red light on ice maker control
Hi
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Thanks
Jul 16, 2009 | Whirlpool Refrigerators
My whirlpool refrig water dispenser and ice maker stopped working
It sounds like the filkter may be plugged up or frozen. check the outlet of the filter to see if the water is going thru. Good Luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
256 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
