Crooked Cpoies When I put a paper in to copy in my canon MF6500 copier the copy comes out but its crooked. (not aligned)
Pull all of the paper out of paper tray and reload. More than likely you will find some sheets on the bottom that are folded at the corners. This will cause crooked copies and also jams.
Posted on Jan 14, 2009
Pages comes out all crooked yet aligned to start with?
Hello sir; onthe paper path there got to have something stuck over there it block the paper go through so crooked. clean up paper chip or paper clip.
Aug 06, 2009 | Canon MX700 Office All-In-One InkJet...
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
My print is crooked.
try to change the ink cartridge and see if that works and also do the alignment after
Jul 20, 2009 | Canon MX700 Office All-In-One InkJet...
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
My Canon MX700 printer prints crooked--did the maintenance too!
Try printing from the rear tray. My printouts from the bottom tray come out crooked, but the ones from the rear tray seem fine.
Mar 01, 2009 | Canon MX700 Office All-In-One InkJet...
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
Images coming out crooked when in copy mode. A hardware problem?
Ensure the guide for the plain paper onto which the image is printed, are pushed up fully. It is possible that the paper is being fed into the paper feed path at an angle if the guides are nut pushed up.
Jun 22, 2007 | Brother MFC-640CW All-In-One InkJet...
277 people viewed this question
jasbo
jasbo
