Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Electric bike cuts out while riding
Sakura shopper 305
  • seby001 May 14, 2009
    Hello!
    My im Gabor. i've recently bought a sakura s305 electic bike. The problem is the following: the battery seems fully fitted but still have trouble when i switch it on, i have to put some paper between the battery and the bike, other wise rearly indicate power or even for a smaller move just cuts off. i can not see how i could fix it.
    thank you in advance for the advise!
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Posted on May 03, 2009
  • Steve Pritchard
    Steve Pritchard Nov 11, 2013
    holds charge well dont work even when i pedal it .sometimes its ok for a few days
    New Friend:
Did you ever get this sorted as I'm having the same issue on a S307, Power everywhere, but nothing happens when twisting the throttle ;-(
Posted on Jun 25, 2013
  • Steve Pritchard
    not as yet but going to check bike frm tip to toe keep u in formed
Hi I have a sakura s305 electic bike my pride n joy it gets me out n about untill now after just parking my bike up going shopping I returned to my bike and nothing full battery lights showing but nothing on the trottle it dont even kick in with the xtra power when I start pedaling ... but was totally fine as I parked it up....please help thanx xx
Posted on Mar 13, 2010
  • Steve Pritchard
    thats same problem with mine
  • Michelle fish
    Michelle fish Jul 13, 2017
    I av a sakura electric bike and one battery conecter./clip had melted.thats done now .soulderd new wires on.now the throttle dunt work done this before it loose slack n.sort of dunt grip how do i mend it plz
How do you open the battery compartment on Sakura shopper to get to batteries
I can find no reference to this particular make / model of camera - please could you supply further details
May 11, 2017 | Cameras
Where can I buy spare light bulbs for my Sakura scooter type bike
Hi, Hendrik any motorcycle/scooter shop will have spare bulbs or check with Amazon.com for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Electric Scooter and Bicycle Troubleshooting Guide
Sakura scooter thing
Question Answer
Jun 04, 2016 | Motorcycles
Sekura electric bike I have power to lights and indicators but the bike wont drive.?
I am not familiar with Sakura, but if it is fitted with e-brakes then you could try disconnecting one then the other to see if it now works. If it does then your ebrake is faulty & you need to replace the brake sensor in the e-brake or the complete e-brake lever.
May 11, 2014 | Electric Bicycle Motor, Bike,electric...
Sakura s305
That is an unusual value. You could try a 25 amp fuse instead as this is a more common value. RS Components or other electronics parts sellers should have them.
Jul 22, 2013 | Electric Bicycle Motor, Bike,electric...
Sakura electric bike .Red and blue cable broken off right hand brake lever. Can I open it and re-solder?
I once spent 2 years and many attempts to solder a VW Bus throttle cable, finally had to get 2 cable clamps and a short piece of wire, fixed it in about 6 min and it never failed again.
Feb 02, 2013 | Cycling
I have a sakura s200 electric bike can i make it any faster ?
Change out the gears with a higher ratio that turns the wheels faster for the same motor RPM. Another method is find a motor that has a higher rpm capability.
Aug 23, 2012 | Electric Bicycle Motor, Bike,electric...
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
Sakura S305 electric bike, no speed control
I'm not familiar with that make/model, but if it has a brushed motor then it is likely that you have a faulty controller module. Most brushed motors have just 2 wires running to them from the controller.
Feb 04, 2010 | Electric Bicycle Motor, Bike,electric...
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
1,536 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
