Question about Rowenta Power Duo Iron
Iron won't heat up!!!
Sometimes the orange light is on - most of the time it seems that there is a electrical short or something because it won't stay on. I am trying to iron right now and it won't stay on! I have tried other electrical outlets in my house and it still won't light up.............so obviously the problem is with this iron. Please help! I know this iron was pretty expensive and it should deliver what it promised!
  • 1 more comment
  • Anonymous Jan 16, 2009
    I have the same problem. The ****** won't stay on. I have started using my sunbeam iron again. I thought it was just my iron, but seems this is a problem.
  • Etkellam Mar 26, 2009
    I have the same problem. This is the 2nd Rowenta iron that I have had this problem and will be the last!
  • maggiem683 Apr 08, 2009
    After about 2 or more years of no problems with this iron, suddenly it doesnt work. I have tried other outlets in the apartment without success. After a few minutes of leaving it plugged in, the 'on' light flickers, but still doesnt heat up. It was very expensive, and I didnt expect this to happen. Thanks.
    New Friend:
  • 18 Answers
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Posted on Mar 06, 2009
  • SkindyLu Sep 08, 2011
    I'd like to bypass this switch also. Which wires to I snip and which do I leave connected so I can still adjust the temperature. Thanks much.
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
We do not have operating instructions for this iron...Shortly after setting heat to cotton or linen and iron heats up,,heat screen commences to flash, red light goes out and iron cools as if disconnected...
No,
either the thermostat or a sensor is bad..
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 13, 2010 | Rival IR800 / IR810 Iron
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
On my iron all of the lights come, but iron wont heat up
Short answer is yes...but you would probably have issues with other appliances also if you had a power surge...
heatman101
Nov 24, 2009 | Euro-Pro Shark GI490 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal FV9255 Iron
i do believe is something wrong with the thermostat or the electronic board.That model i do believe(but i`m not sure) have a small circuit board controlling the temperature and the safety.Make sure also your thermostat handle is working properly because sometimes the connector between the handle and the thermostat can get bad and not adjusting the right temperature
Fabio
Jun 20, 2008 | Tefal UltraGlide 1759 Iron
Rowenta Power Duo Iron Logo
904 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
