Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer is leaking water at bottom
Leaking at the bottom and not draining water in a spin other then maybe on the floor
  • 641 Answers
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Posted on Jul 31, 2007
3 Suggested Answers
SOURCE:
  • 883 Answers
SOURCE: My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
Posted on May 31, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My hotpoint 430 washing machine won't drain and very noisy when it spins.
first u check the water pump at the bottom side of the washer open it u will see a nub open it and u can also drain the water 4rm there but it will mess the floor up then if it continues contact ur engineer about the spin mayb the load in it is much or u set the washer balancing
Jul 26, 2011 | Tecnik TKL9260 Front Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
On spin cycle water leaks from under the washer all over the floor
First thing is to make sure the washer is level and balanced, use the screws on the bottom and a level. Once level run and see if leaks. Also move closer if possible to the place the water drains to(or is supposed to drain to). If there is know leveling screws check manual to get part number to order, but first check other solutions as not to waste cash on screws you don't need.
Jan 31, 2010 | GE WBSR3140DW Top Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Atf 6000 front loader not spinning or draining
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
596 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
