Question about RCA F27669 TV
Snapping noise and flickering pic when set is first turned on
When the tv is turned on, after it has been off for several hours or overnite, it emits a clicking or snapping noise, in conjunction with the pic kind of flickering. this happens in four or five quick short bursts, but is fine as it is left on, this has increased, since when it first started happening, it only would happen once, or not even everyday. now it's everyday.
    New Friend:
  • 129 Answers
The hi voltage cable a red wire with gray cup that its attached to the picture tube needs to be sealed , that can solve the problem. 40.00 dls depending on the tech . dangerous to do without the knowledge ,picture tube need to be discharge before, try to seal to avoid accidental hi voltage discharge . if you need more help let me know
Posted on Jun 14, 2007
MY TV STARTS EMITTING A BUZZING SOUND AFTER IT'S BEEN ON AN HOUR OR SO. It is a Samsung DLP model HLP5063WX/XAA.
Its likely to be the color wheel which when fails can do several things: A high pitched whine or what is often described as a fan like sound.
Since the set monitors the speed of the wheel if it slows down even a little image may look odd or dark.
you can at worst hear a grinding sound and it means segments in the wheel are shattered or missing
Good news is it is readily available and many average people can replace it---you tube even has video instructions for most of the Samsung models for this.
Only two models were made and Google the model number with Color wheel to locate the one your set uses.
Dec 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Red noise or flicker on bottom half a plasma screen
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
I have an LG - LCD 32LB9D TV that turns on and cuts out several times before it stays on. It makes a high pitched noise(like a falling firework) each time as it turns off. It's connected up to a...
I have seen this problem several times. It is caused by faulty digital audio/video processing circuits. If I am not wrong, thehigh-pitched noise is emitted from the speakers, rather than the boards at the back of the set. Replacing the main A/V board should resolve your problem. It is easy to replace and costs about 75-100$ for a set of this size. Let me know if you wish to do it yourself so that I can find you a replacement board.
Aug 15, 2011 | LG Televison & Video
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
T.V. would take about an hour to warm up.
I have answer serveral times about this ck 3 capacitors on deflection board.cp150- cp111- cp114
Oct 02, 2008 | RCA D52W19 52" Rear Projection Television
Green power on light flickers
I can help if anyone with this problem lives in Anaheim CA.
Jan 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flicker after warm up
Arcing noise suggests HV leak--get a tech to look at set!
Oct 03, 2007 | RCA D52W19 52" Rear Projection Television
RCA model# D61W136D scenium
Sounds like the high voltage transformer is bad. Best bet is to call a service shop. I wouldn't keep watching the set, as this will just cause more damage.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
Problems when turning tv on from cold start
the bad news first you'll need to replace the deflection board . the good news you can order and .replace this part by yourself. partstore.com is the website to order the part good luck if you need more help , let me know
Jun 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F27669 TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
