SOURCE: Hitachi 43fdx20b blurred Picture
Yes this is a normal diagnoise. Just about every Tube type projection TV set ever made will one day need these IC's replaced. They are not really that hard to replace but you would need to know how to solder and unsolder on printed circuit boards, know the procedture, and then have a service manual handy to adjust the convergence after yoou replaced the IC's. If the tech works on alot of these types of TV sets's, most likely they could adjust them without having a service manua handy. This repair done by a pro should run you anywhere from 250 on up to 400 bucks depending on who does the repair and where. Good Luck
SOURCE: 43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
SOURCE: Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
SOURCE: Hitachi 43FDX20B, watching tv, screen went blank,
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
