Question about Uniden DXAI7288-2 Cordless Telephone
Connecting the hand sets
I have the uniden 2.4GHZ dual hand set phone, and it hasnt been connected for a year or so how would I go about connecting the phones so that they both work? And also, how can I change the voice message on the answering machine to change it from being the memo to a personal message?
SOURCE: How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
Posted on Jan 17, 2008
One Wire
  • 126 Answers
SOURCE: exai 918
here is a link to the pdf format owners manual for the Exai 918:
http://www.uniden.com/pdf/EXAI918om.pdf
Posted on Jan 26, 2008
OldLinuxGeek
SOURCE: uniden cordless phones
Okay, this solved it for me, so maybe it'll help others.
Basically, you just need to re-register the phones by placing each one on the base unit and leaving it there for at least five seconds after the charge/in use LED light stops flashing.
According to the manual, it's necessary to re-register each phone after a power failure or if the batteries get very low or die. If you're experiencing the "connecting..." problem, this will probably fix it!
Posted on Oct 23, 2008
SOURCE: two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
Posted on Jan 09, 2009
divatif
  • 39 Answers
SOURCE: Uniden PowerMax5.8 GHz
Yes, it will automatically let you know when you have a voicemail. If it does not work, contact Comcast.
Posted on Mar 18, 2009
I can't retrieve incoming calls. Often the phone keeps ringing after I pick up the handset. My Phone is Uniden 6.0 DECT 1635+1 - 58004699.
change the phone set up to --answer on lifting hand piece
It may have glitched and now requires you to press talk to make the connection
Jan 28, 2018 | Uniden Lands Phones
I bought my Uniden phone XDECT 8155e - home phone two years ago currently the phone hand sets are flashing for the last few weeks please assist?
As this is a mobile phone, more people on the forum dealing with such equipment are likely to be able to help you.
Jun 29, 2017 | Cameras
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
Can i add 3rd handset to uniden xs 1455+1 cordless phone
if you can get the exact model as the existing hand set it should not be a problem
just follow the installation process to get the base to recognize it so that it connects
Dec 05, 2015 | Uniden Cordless Phone
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
Uniden XDECT 7055 hand set problem
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
Jul 01, 2010 | Uniden Cordless Phone
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Answering machine rings
you can set them for 2 or 4 rings.
May 30, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden cordless phones
Mar 21, 2008 | Uniden Cordless Phone
Uniden DXAI7288-2 Cordless Telephone Logo
32 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
