Question about Sharp AL-1642CS Copier
Printer will not prite anything you press anything and nothing happens it flashes L1
  • 32 Answers
Most common cause is the locking mechanism beneath the scanner section. Unlock it.
Posted on Jul 11, 2009
  • Sharp Expert
  • 257 Answers
L1 means copy lamp problem or mirror drive problem. Check that area.
Posted on Jul 01, 2009
How do I turn on the flash?
If the flash even does to fire, while the camera is on automatic and it is a dark scene, you have to fear the flash is defect.
Jul 03, 2014 | Nikon Coolpix L1 Digital Camera
When I entered my data in L2 because in L1 I don't know what happened is not on the screen then I press STAT and select CALC, then select 1- Var Stats and press enter I should be able to see the mean,...
When you select 1-Var Stats, specify L2. If you don't specify a list, the calculator will assume L1.
You can recreate L1 by pressing
2ND [{] 1 STO 2ND [L1]
{ is on the ( key.
L1 is on the 1 key.
Jan 27, 2011 | Texas Instruments TI-84 Plus Calculator
PRINTING RED LETTERING INSTEAD OF BLACK. REPLACED
well you need to clean up ur printer it just needs a little bit of servicing , it happens when the printer is dusty because of which the sensors are blocked and because of which this problem happens...it happened in my computer..
Nov 06, 2009 | HP DeskJet 6540 InkJet Printer
Coolpix L1 that won't take a picture after getting wet
try dismantling you will find a gooey substance in a microchip. try removing it.i hope it works
Sep 12, 2009 | Cameras
Epson C84 paper light is on and power light is flashing what can I do?. E Green.
Please check if there are any foreign objects inside the printer. And unplug it from the computer and test if you can print just using the printer itself without using the computer.
Make sure there is paper loaded on the printer and the printer is OFF.
Hold down the paper button and press and release the power on switch, if you can see flashing green light release the paper button. Just wait till it feeds on paper. If it feeds on paper and prited on a pattern it means the printer is working fine, but if not you have to call your manufacturer of your printer.
Feb 28, 2009 | Epson Stylus C84 InkJet Printer
Flashing l1 and wilkl not do anything
Next exit paper put knob to key off position. Power off and power on.
Jan 14, 2009 | Sharp AL-1642CS Copier
Check printer & alarm flashing.I cannot get it to reset.
Electric connection terminals scratched? Maybe short circuit. Use warranty from purchase for repair.
Sep 29, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red...
Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
Aug 21, 2008 | HP Office Equipment & Supplies
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
