Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
The DHCP client service is not running on this computer
  • 59 Answers
Start the DHCP Client Service, and then set it to start automatically at startup. To do so, follow these steps:
  1. Right-click the My Computer icon on your desktop, and then click Manage.
  2. In the Computer Management console, double-click Services and Applications, and then click Services.
  3. In the rightmost window, right-click DHCP Client and then click Properties.
  4. Change Startup type to Automatic, and then click OK.
  5. Right-click the DHCP Client service again, and then click Start.
Posted on Jan 14, 2009
Acer d225e loses wifi connection
allright,most of computer that connected to a wireless network obtain an IP address from the server.so,it looks like your computer cannot obtain the IP address from the server,perhaps your DHCP client service is stopped or disabled,in order to fix the problem,you will need to check the DHCP client service and make sure that it's run properly. Click Start->Run->type "services.msc" and a window that shows all service on your computer will appear. look for DHCP Client service and see if it's disabled or not running. if it's disabled,right click on it and select properties.on the Startup Type,select Automatic.and right click on the DHCP service and select Start. if it's already started or it's not fixed the problem (and i think it would),it might be that your connection get much inteferences that 'damage' the signal (because there are too many users that also uses wireless on the area),you can fix it by changing the channel with this software. http://www.metageek.net/products/insside... try to use channel 1 or 6 or 11. there are many other reasons such like insufficient Wi-Fi network range and power (it's the signal,take your laptop closer to the access point to get stronger signal),your Network driver need to be upgraded,or Overloading (overheating) on the Wireless device. Just ask me another question if you need something,i will answer it untill the problem is fixed
Aug 28, 2012 | Acer Computers & Internet
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Tip
IP ADDRESS.. 0.0.0.0 troubleshooting
<p><b>Symptom:</b><br /> loadTOCNode(1, 'symptoms'); <p>When you use the ipconfig command to renew your computer's IP address, either of the following behaviors may occur: <br /> &bull;<br /> You may receive the following error message: <br /> <p>An error occurred while renewing interface local area connection. The system cannot find the file specified.<br /> -or-<br /> &bull;<br /> The command may return the IP address and the subnet mask 0.0.0.0.<br /> <p><b>Resolution:</b><br /> loadTOCNode(1, 'resolution'); <p>To resolve this behavior, use the following methods in the order they are presented. Before you start, restart your computer. After each method, test to determine whether the issue is resolved. <br /> <p><b>Method 1. Turn Off Firewalls:</b><br /> <p> loadTOCNode(2, 'resolution'); Make sure there are no firewalls and that Windows XP Internet Connection Firewall or Windows Firewall is turned off. <br /> &bull;<br /> If you have a third-party firewall installed, disable it. <br />For information about how to disable your firewall, see the product documentation, or contact the technical support department of the manufacturer.<br /> &bull;<br /> Turn off Windows XP Internet Connection Firewall. To do so, follow these steps: <br /> 1.<br /> Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.<br /> 2.<br /> Right-click your connection, and then click Properties.<br /> 3.<br /> Click the Advanced tab, and then click to clear the Internet Connection Firewall check box if it is selected.<br /> <p>If you use Microsoft Windows XP Service Pack 2 (SP2), follow these steps to turn Windows Firewall off: <br /> 1.<br /> Click Start, click Run, type <span>ncpa.cpl</span>, and then click OK.<br /> 2.<br /> Right-click your connection, and then click Properties.<br /> 3.<br /> Click the Advanced tab, and then click Settings. <br /> 4.<br /> On the General tab, click Off (not recommended).<br /> <p><b>Method 2. Verify That Your Network Card Is Installed Correctly:</b><br /> <p> loadTOCNode(2, 'resolution'); Verify that your network card is installed correctly. To do so, follow these steps: <br /> 1.<br /> Right-click My Computer, click Manage, and then click Device Manager under Computer Management.<br /> 2.<br /> Expand Network Adapters, and then verify that your network adapter is listed. <br /><br />If your network adapter is not listed, use the following methods in the order they are presented: <br /> a. <br /> Update or reinstall the driver.<br /> b. <br /> Move the adapter to another available slot, and then reinstall it.<br /> c. <br /> Replace your network adapter.<br /> <p><b>Method 3. Verify That the Dynamic Host Configuration Protocol (DHCP) Client Service Is Started:</b><br /> <p> loadTOCNode(2, 'resolution'); Verify that the DHCP Client service is started. To do so, follow these steps: <br /> 1.<br /> Right-click My Computer, click Manage, expand Services and Applications under Computer Management, and then click Services.<br /> 2.<br /> Verify that the DHCP Client service is running.<br /> 3.<br /> If the service is stopped, right-click DHCP Client, and then click Start.<br /><br /><b>Note:</b> If the service does not start, a dependency group or service may also be stopped.<br /> <p><b>Method 4. Modify the Registry:</b><br /> <p> loadTOCNode(2, 'resolution'); <b>Warning:</b> Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.Make sure that the DHCP registry entry is correct. To do so, follow these steps: <br /> 1.<br /> Click Start, click Run, type <span>regedit</span>, and then click OK.<br /> 2.<br /> Locate the following registry key. <br /> <p>HKEY_LOCAL_MACHINE\System\ControlSet001\Services\DHCP<br /> 3.<br /> In the right pane, double click DependOnService, and then make sure that the Data Value value is Tcpip Afd NetBT.<br /> 4.<br /> Restart your computer, and then verify that the DHCP service is started as described in Method 3.<br /> <b>The information in this article applies to:</b><br /> &bull;<br /> Microsoft Windows XP Home Edition<br /> &bull;<br /> Microsoft Windows XP Professional<br />
on Mar 15, 2011 | Computers & Internet
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
Need to add a computer to the DHCP client list of Belkin router
You can't add a computer to DHCP Client table manually, because DHCP client table is automatic. If you wanna know the MAC address of your computer, go to Start > Run > type CMD and press enter. On the command prompt type in IPCONFIG/ALL and look for Physical Address. That is also the MAC Address of your computer.
Jun 28, 2009 | Belkin (F5D9230-4) Wireless Router...
Tip
IP address 0.0.0.0
First of all, disable and re-enable the connection. When you change the IP address from automatic to a fixed IP address while the adapter is not connected, you always get a 0.0.0.0 address at first when the adapter reconnects. If this doesn't solve the problem, read on.
Symptoms:
  • You cannot obtain an IP address from the DHCP server. The IP address is 0.0.0.0.
  • The DHCP service is not running, although it is set to Start Automatic.
  • When you try to start the DHCP service, you get the error message: Could not start the DHCP Client Service on Local Computer. Error 1075: The dependency service does not exist or has been marked for deletion.
This problem can occur after uninstalling Norton AntiVirus, which sets the DHCP service as depending on itself. It can also occur when the computer name of the client computer is too long. Make sure that all computer names in your network are no longer than 15 characters.
First set a restore point, so you can undo your changes, should anything go wrong (Programs, Accessories, System programs, System restore).
After setting the restore point, to remove this dependency, do this:
  • Click: Start
  • Click: Run...
  • Type: regedit
  • Click: OK
  • Navigate to the following keys in the registry:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\DHCP
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\NetBT
  • For each of these, on the right side, double-click: DependOnService
  • Delete any lines containing either SYMTDI or NISDRV.
  • Click: OK
  • Close the Registry Editor.
  • Reboot.
on Mar 29, 2010 | Computers & Internet
Hot to start dhcp client service
If it worked before then your settings of somehow been changed
follow these steps
let me know if it helped
open network connections
right click your connection
status
then support
then repair
Jan 14, 2009 | HP Pavilion dv6000z Notebook
Dhcp client service
Click "START",
Click "RUN",
Type: services.msc
Hit enter,
The services applet will open.
Scroll down through the services untill you find "DHCP CLIENT".
Right click on "DHCP CLIENT" and then select "START" from the options menu.
Jan 14, 2009 | Microsoft Windows Vista Home Premium with...
Right mouse click "My Computer". click "manage", on the left hand tree click on "services". Now on the right hand pane, find DHCP and double click it. Select automatic in the scroll window. Then on the top left of this pane, click on "Start".
DHCP client services not running
Try to set a static ip address, this is a common problem in Windows Vista.
Jan 13, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
