The dryer complaint of "No Heat At All" can be a couple things for a given gas or electric dryer. (Keeping in mind; Insufficient "too long" to heat is a different type of complaint)
Defective Ignition Systems
For Gas Dryers; Thermal fuses (white - very likely), Gas valve coils (black; battery size; likely), Thermal Sensors (black, square; rare, but likely) and also Electric Ignitors (Glows red; likely) are very common for "no heat" complaints.
For Electric Dryers: Hi/low limit cut-off switches (Very likely) and electric heating element/coils (Likely) are very common. Also, tripped breakers for electric dryers (Very likely; may only be receiving 110v instead of the 240v needed)
With respect to your dryer vent-line; the line may be clamped down too tight. You may need a 1/4 screwdriver to loosen and remove (assuming it is not taped down)
-C
Kemore electric dryer won't get hot. Could it be because the outside temp. has been so cold and the dryer is located in an "addition" to house with not so great insolation?
i am having the same problem with my kenmore dryer as well. any help would be much appreciated. i have checked the lint trap, the duct, and the circuit which are all fine. HELP!!!!
Is this a gas or electric dryer? Please post more of the model number.
what is the problem with the dryer?
