Question about Gigabyte GA-8I945P-G Motherboard
Incorrect Memory Count
Hie , im using the 8i945P-G mobo and just recieved 4 (!) G.skill pc2-6400 1024 sticks ... wich is good so far. thwn i installed the first 3 the bios identifies them correctly and shows 3072MB of ram when i add the forth stick it increases the ram to 3400 ... i'v tried to change places of the sticks, use diferent combination and even tried it with a 3*1024 +1*512 ... still the bios says that i got 3400. the funny thing is that windows (xp64) shows 3250MB YET CPUz shows all the 4G correctly i'v updated the bios to it's latest (F11) version and still nothing *** i know that the Mobo supports ram up to 667Mhz and those are 800Mhz sticks *** but it suppose only to alow them down (and its realy good 4 OC coz the *** Mem runs @ it's natural speed when i'm using 250 FSB (3000@3700 Mhz) any idea what may cause this messup ???
    President:
  • 2,961 Answers
Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. __For example, 4 GB of memory size will instead be shown as 3.xxGB memory during system startup.____To use a DDRII 667 memory module on the motherboard, you must install an 800/1066MHz FSB processor.____Please also refer to the image below
Posted on Jun 14, 2007
  • andrew pester
    andrew pester Jun 14, 2007
    if you need more info on your board, you can get the manual from here:-
    http://europe.giga-byte.com/FileList/Man...
SOURCE:
Im using psp 3001 with version 5.03 PROME-4...Ads by GoogleInflatable Movie Screens www.OpenAirCinema.usSeamless, high quality screens Portable, washable, outdoor screens By richmond_sic on Mar 07,...
You should have not installed ChickHen in your PSP 3001 since there are no known ways so far, not even by Dark Alex, to fix it from "Brick"-ing. YOur attempts to remove the battery and so on to fix it is futile because even Pandora Battery and Magic Memory Stick won't work on those versions of PSP.
Try sending it to S0ny...
If you intend to buy a new PSP, either buy those Slim that is version 2000 and those that are NON (remember NON) TA088v3 MoBo. From this MoBo onward to PSP 3000s, all is unhackable and cannot be fixed from Brick.
May 31, 2011 | Sony PSP (Piano Black)
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
How much ram and at what speed will i get best performance all around onn a P4P 800M mobo ? Is running a 2.4G asus processor and has 2 256 sticks running at 44g mhz. I would like to use 1 gig sticks but...
As far as i remember that motherboard has 4 DIMM (ram) slots supporting a maximum of 4GB DDR400/333/266 memory also it has Dual Channel Memory Architecture.
Regards.
Apr 21, 2011 | ASUS P4P800 Motherboard
Ok i have 2 1gb corsair memory sticks and when i put them both in they wont work but when i use one it will its the slot on the mother board i think is there anyway to fix it
try the known good memory stick and try to reseat the memory stick to every slot that your mobo have. so you would know if the problem is with the mobo or the memory stick itself
Mar 29, 2010 | EliteGroup ECS 915P-A2 Intel 915P Socket...
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
Motherboard compatibility
If you want to replace the mobo always compare the cpu-slot and the memory slots.
Tok a fast look on both of the mobos and both supports same cpu, both supports same memosticks though the the one you have supports ddr2 667mgz and the new one you found supports ddr2 1333+mhz. So you can use it but you may have to buy faster memosticks if you want to use the full power of it.
Here is the support site for the new one:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2843
On that site you will also find all the drivers you may need if you buy it
And here is the support site for the mobo you have:
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ClassValue=Motherboard&ProductID=1960&ProductName=GA-8I945P-G-RH
Now you can compare yourself if you want.
BTW, that GA-EP45-DS3 is a very good mobo
Good luck to you
Please take a moment and rate my help for you
Nic
Feb 18, 2009 | Intel Motherboard
Compatible vid card for my foxconn P4M9007MB MOBO
You will be fine with nVidia 9800 ! thats perfect for your mobo.
Youst make sure you have enough of memory to, those games you talking about needs a lot of memory to work perfect.
I suggest you install at least 3GB memo, or even better 4GB. Thats the maximum of memory you can have on that mobo.
Here is the spec of your mobo
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000243
Good luck to you
Dec 17, 2008 | Computers & Internet
Will not POST with 2g of kingston hyperX ram inside
If you are going to call. The question I would ask (Very important), will the board run with CL2 = 2.5v & or CL3 = 2.6 to 2.65volt memory.
This site is Kingston memory setter. Type in the board & it show's the type of memory the board can use. (Click on this link). As you look at the link this is for you're P4M80-M4 board.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=33018&mfr=Biostar&model=P4M80&root=&LinkBack=&Sys=33018-Biostar-P4M80-M4+Motherboard&distributor=0&submit1=Search
This should help. I did not see a bios upgrade for this board that had anything to do with memory. The USA Biostar link is lacking opposed to the global link. The global manual give far more information (In depth), for bios instructions.
Global link: http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
I'm sure the Kingston link will more than help you the_OCer.
Mike
May 21, 2008 | Biostar P4M80-M4 Motherboard
GA-8I945P-G 4GB Ram Problem
you maybe have integrated VGA card or Shared memory VGA card that use the memory in your pc .. your best solution is to buy new VGA Card that have dedicated memory
Dec 28, 2007 | Gigabyte GA-8I945P-G Motherboard
Gigabyte GA-8I945P-G Motherboard Logo
154 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
