Where do I find a repair person to come to my apartment and fix my washer?
  • 15,935 Answers
Yellow Pages.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Repair old water intake valve bosch nexxt washer
You can take apart your water supply valve and fix it but this won't last long and you'll be taking it apart again soon to put in a new one-so,skip the rebuild and install new-life is too short-cheers Denny
Oct 25, 2013 | Bosch Axxis WFL 2060 Front Load Washer
JSROCK saved the day....I can usually find parts on the internet, but taking...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Nov 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer won't spin. I cleaned the clogged pump, but it shows thes two codes
I've had the same issue, and a close friend that had a similar issue. Here are the 2 resolutions:
1) Check the drum in between the body and the actual barrel. Sometimes small articles of clothing get stuck in there and will cause the barrel to not spin (such as a child's sock).
2) Some barrels are only made to spin when the machine is cycling. If for any reason you or someone else spun the barrel with your hand (when pulling laundry out for example), the spinning mechanism can become unattached. In that case, you will probably want to call a repair person rather than taking the washer apart yourself. This is a relatively easy fix for a good repair person so it shouldn't be very costly.
Hope this helps.
Nov 28, 2012 | Washing Machines
Wont drain or spin, we have drain it and started it again and it still wont drain
The pump is either broken or the drive shaft coupler is bad. My wife and I recently fixed our washer. i was inclined to get a service person to do it for $300 bucks but she started to take it apart. It wouldn't agitate, but it would pump. The coupler ended up costing us $17 dollars and we fixed it. Hope this helps.
Jan 22, 2011 | Samsung WF203ANW Front Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Oven door does not consistantly shut completely
There is alot of unit that I personally repaired for the same problem. I designed a quick fix for it without changes the hinges. It is a little bit technical. The door has to be to took apart and in will need three washers on both sides of the hinge. this will be a $1.00 do it yourself fix if you dont have any appliance repair can fix it for you.
Feb 02, 2010 | Bosch HGS 255 Gas Kitchen Range
I have a rental unit with this washer/dyer make and the tenant has told me that there is water licking from the bottom when the first cycle is going through. I have changed the hose fittings at the back...
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 02, 2009 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 110 80 Series. Agitates, fills, won't spin
This is most likely the lid/door switch loose in its mount or, switch has dirty contacts or, it's broken. The lid switch is a safety feature which keep the tub from spinning if the lid/door is up/open.
Don't know if switch comes apart to clean contacts, but if its tight in the mount (which means loose mount is not the problem) then you could remove it, soak it in rubbing alcohol for a while to clean it (if you can't easily take it apart and reassemble).
Aug 26, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
