FixYa.com
Tags:
Casio Exilim EX-Z57 Digital Camera
Casio Exilim Z57 Date and Language set up (by 6 users)
posted by newbie2020 on Jun 14, 2007
Everytime i turn on the camera, it goes to the Date and time set up. I select the values and hit set but next time i restart my camera it takes me back to the same place and asks me to select language/date and time.
Can some one help..
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Jun 02, 2008
No luck with format. Any other options?
Comment by abomb21, posted on May 17, 2008
My casio exilim ex-z75 conveniently stopped working its magic a couple of weeks after its one-year warranty expired. Each time that I turn it on the language/time/date settings insist that they be reset. It is possible to bypass this problem by simply pressing the 'menu' button. However, in doing so, it is impossible - or at least I have found it to be, to upload photos in their chronological order. This is annoying - especially when you take a gazillion photos like I do. I have tried to reformat the memory to no avail. I called Casio and they suggested that I send it in to be repaired. The cost of which, they estimated, is between $40 and $119. As the camera's current listed price is $120, this really irks me. But enough about my bitterness.
Comment by Guest, posted on Apr 21, 2008
I have the same problem and unfortunately, formatting the internal memory does not seem to work... am i doing this wrong or is it more serious problem?
Comment by rwmm415, posted on Apr 09, 2008
Exactly the same symptoms. Anyone figure out a user-level solution?
Comment by anealon, posted on Nov 06, 2007
I have the same problem. How do you reformat the internal memory???
Best Solution
Thanks for Trying (70)
rwmm415
Rank:Apprentice Apprentice
Rating: 78%, 6 votes
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 20, 2007
Not Rated (0)
newbie2022
Rating: 0%, 0 votes
I got this resolved by formatting the internal memory
Solution #3
posted on Jun 14, 2007
Not Rated (0)
jackboy
Rank:Wiz Wiz
Rating: 76%, 3468 votes
Check the Casio technical support team- this seems to be an internal failure0 unless of course there is some you missed in the manual- check that thoroughly first.
Can you Help with these Digital Cameras problems?
Video feature
I know how to use camera to... Answer This...
my camera wont turn on right
i left it in my purse for... Answer This...
orange flashing light--does not...
my camera turns on and the... Answer This...
Transfering pictures
My camera transfers 2 pictures... Answer This...
Panasonic Lumix DMC-FZ5
I dropped my camera and the... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
