My PC does not boot when I press the power button on. The power comes alright but it will not boot and load files unless I leave it on for a long time and later reboot it again. This has been the problem for sometime now and I decided to take it that, the Intel Mother Board Intel D845PEBT2 needs to get heated up before it finally boots. I wish to bring this issue to your notice so you can help me out. Another issue is that, it always reports a system date change(Problem with the C MOS date after it finally boots (thus during the booting up process). A computer technician in my area advised that I should change the CMOS battery, I inserted a new CMOS battery but the problem remains the same. Please help me.
  • DEKR
    DEKR May 11, 2010
    Is your time in the task bar showing the correct time
  • 85 Answers
You need to clear cmos usually on board is a little coloured jumper,but also first disconnect power plugs from board which come from the big psu,normally have a little clip you have to squeeze,find cmos normally 3 pins with a littl jumper move it from one set of pins to next set of 2 pins,you normally have i pin exposed,so move left or right and hold for 10 seconds make sur e you put back as it was,reconnect psu plugs ,reboot enter the bios normally Delete button or what it says on your screen normally setup button ,reset your time and date and make sure you save your settings before you leave bios page
Posted on Jan 15, 2009
On the main screen nothing else shows up but the backup ground picture . nothing else will show up . what can i do
Try pressing Ctrl + Alt + Del. If it isn't completely frozen, it should bring up the task manager. Open file -> new task (run). Type "explorer.exe" without the quotes and press enter. This should open the task bar.
If that doesn't work, hold the power button for 10 seconds to do a hard reboot and see if it boots past that the next time you load. If not hold the power button for another 10 seconds and press F8 while the computer is booting up to enter safe mode. If you can get into safe mode, use a restore point to go back to a date when it was working.
Please leave feedback if this was helpful. Thanks.
Mar 21, 2011 | Acer Aspire One PC Notebook
Win 7 upgrade disc not recognized
alright when your computers Boots up it tells you several options such as F2 or F12 when you press this another menu should come up you need to change the way your computers boots up isntead of the harddrive put the CD/DVD rom FIRsT than the rest save and exit your windows 7 disk should be already IN!!! than it will load the little dot will be loading than it will tell you to boot from the disk press any key! press whatever and it will take you to WINdOWS 7!!! i hope this helps you and please leave positive feedback!!
Jan 17, 2011 | Gateway GT5428 PC Desktop
HP 2133 PC Notebook Black Screen
win32corrupted boot sector try recovery cd which come along with ur laptop
Jun 06, 2009 | HP 2133 Notebook
My computer(Compaq 5301RSH 5000 SERIES) won't start because "Windows could not start because the following file is missing or corrupt: system32hal.dll. Please re-install a copy of the above file." What can...
Alright..Not a big problem..Generally happens due to some files corrupting. Put your Windows CD in the drive, boot form the Disc and choose to repair the operating system. The problem will be solved.
Thank you!
Sabharish
Jun 04, 2009 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
HP Laptop DV2415NR Need to power on twice to boot.
log in your bois and make sure first boot option is hard drive. not cd/usb or anything else. unless you need to
Apr 18, 2009 | Dell Latitude D600 Notebook
Boot up problem
There could be a number of things wrong here are a few things you can try if you are confident in your ability inside the computer case.
Reset the ram
Double check the CPU cooler and make sure that it is in the correct position
Double check the CPU coolers power connection to the three or four pin power connection
use Canned air duster and clean any dust out( be sure not ot let the fans spin freely while blowing)
If confident reapply thermal paste and thoroughly clean off older paste(any residue may affect cooling performance)
Jan 29, 2009 | Computers & Internet
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
My Computer Does Not Boot
If your system is still not holding the date and time after changing out the CMOS battery, then ther is what is called a "cold" solder joint on the motherboard thjat might work, as you mentioned, after the system is warm.
However, sicne the system does boot up and operate later, it is more likely that the power supply has the issue and is not delivering power properly until it stabalizes.
Get a replacement PS, just make sure that it has at least the same wattage as the original one. You don't even have to physically install it at first, just swtich all the connections from the old one to the new one and see if the system comes up right away. It is does, then do the swap. If not, you can return it and replace the motherboard.
Jan 10, 2009 | Computers & Internet
Won't turn on when I press the front button
This sounds like your power supply; it's the part that the power cord plugs into that converts the power to dc and powers your motherboard, drives, and everything else inside your computer. You can pick one up for around $30 online or $80 at a retail store.
Thanks and please take a moment to rate as fixya.
Sep 08, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
619 people viewed this question
David Payne
David Payne
