Question about Canon XH A1 Mini DV Digital Camcorder
Getting poor quality uploads to my pc from my Canon XH-A1
I'm getting very poor quality uploads from my dv tapes when I upload them with my Canon XH-A1 HDV camcorder.
I get a wavey green band at the top of the video when I play it back in windows media player.
Is this a known issue with this camcorder? How do I correct it?
I have no problems when I use my Sony FX7 for uploading.
  • gecatgjc Jan 15, 2009
    Downloaded it and tried to use it. It wouldn't work. It wouldn't capture anything.
    Problem Solver:
  • 15 Answers
You need to upgrade you ingest system. Windows Media Player(and your system card) probably can't handle the load. Try "Scenalyzer" it's economical, versatile and stable( http://scenalyzer.com/).
Posted on Jan 14, 2009
  • Pete Wilkerson
    Pete Wilkerson Jan 15, 2009
    Try uploading in SD instead of HD? Even the trial version of SCLive should capture the 1394 signal(with a watermark). I'll keep thinking and asking.
    vac8
Canon Xh a1 won't turn on, HDV and Power are blinking
It could be the blown fuse that located on the main circuit board.
Dec 18, 2014 | Canon XH A1 Mini DV Digital Camcorder
Why won't my Canon XH A1 power up
The most likely cause is a component failure in the power circuit. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Here is a link to a repair shop that should be able to help you.
www.discountcamerarepair.com
Nov 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
MacBook Pro/FCE does not capture video from XH A1 any more. Message: Cannot initialize HDV deck-please connect camera.
Play the tape on the camera before connecting it to the mac and loading up the software. You could always see if iMovie is giving the same error message too... This usually fixes the problem for me and usually arises when switching between SD and HD on the camera.
Dec 22, 2009 | Canon XH A1 Mini DV Digital Camcorder
XH-A1 Non Recogition
I occassionally have this issue, what you need to do is set the camera playing BEFORE you connect and load up the software. This should then show an image in the import settings in iMovie or whatever you are using. If you are using iMovie, do a manual import and rewind the tape on the camera manually with the import just running. When I do this it usually solves the problem for a while but every now and then it'll arise again, usually when switching between using HD MiniDV tapes and the standard ones and hence switching between SD and HD recording on the camera, seems to confuse it somewhat...
Aug 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Jul 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
Its a canon XH-A1
Please go to Display setup > TV Screen display > OFF
very simple procedure.
Dec 20, 2008 | Canon XH A1 Mini DV Digital Camcorder
Playback STD Locked Playback is Restricted message
the tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Nov 05, 2008 | Canon XH A1 Mini DV Digital Camcorder
Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Jan 26, 2008 | Canon GL2 Mini DV Digital Camcorder
Clicking sound wont stop
Maybe theres a bug in the battery.
Jul 12, 2007 | Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 Mini DV Digital Camcorder Logo
193 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
