Question about Compaq Evo N610C Notebook
Boot - Compaq Evo N610C Notebook
  • 3 more comments
  • djfgbr Jan 15, 2009
    Dear cpenzes,
    Please see the communication I had with one of the members who was kindly trying to help me yesterday. Please let me know if any suggestion you have. Problem is not sorted out yet.
    Thanks
    Dear cpenzes,
    Please see following the conversation between me and one of the members. I did lots of suggestions but no luck. Thanks for your help.
    Cheers
    'Boot from CD' does not work.
    var g_tryMail = 0;
    function addthschng()
    if($i('at_email') != null)
    addthis_sendto('email');
    else
    g_tryMail++;
    if(g_tryMail
    Report abuse
    posted by djfgbr on Jan 14, 2009
    My
    laptop shows a blue screen in booting process and suddenly restarts.
    Message in the blue screen: unmountable- boot- volume. I tried to boot
    from cd but seems the multibay does not recognise the cd and there is
    no other option in BIOS to boot from cd.
    Your help is most appreciated
    Jafar
    Comment posted on Jan 14, 2009
    Thanks
    guys for the reply. I get to the bios by f10. there are only 2 options
    via hard d and via multibay. tried both no luck. also tried f8 for
    advanced windows options, not such option!!! safe mode stops in midway
    too.
    cheers
    there are options like last worked configuration, safe mode, networking etc but no usb or cd boot stuff
    cheers
    No
    luck mumma_1, there are only 2 types of settings appearing (not with f1
    or 2), but with f10 and f8, no option as boot from cd. Does multibay
    mean a kind of boot from cd?? however, not recognises the cd though.
    can i erradicate OS and install in from scrach??
    Thanks
    Comment posted on Jan 14, 2009only the windows, not floppy drive but usb port
    Comment posted on Jan 14, 2009hi, i tried delete button as well but no difference! i am sorry to be difficult
    Comment posted on Jan 14, 2009there is not such a option there. also the options for start from floppy diskett is inactive
    Comment posted on Jan 14, 2009as far as i know it does not have such partition but i am going to try
    Dear mumma_1,
    Thanks
    so much for your time and help. The main issue is that all solutions
    require the laptop be able to boot up from cd. If I can sort this issue
    out then other solutions will work. I have to leave my desk now. Thank
    you again.
    Cheers
    J
    Still need a solution for this problem?
    Try our Premium Assistance plan
    Clarification Request
    Posted by watcha523 on Jan 14, 2009Does the bios allow you to boot from floppy, or USB device.... have you tried to read the CD from another PC/Laptop?
    Solution #1
    mumma_1
    Rank: Wiz
    Rating: 85%, 360 votes
    You
    should definately be given the choice to boot from cd, when you press
    F2 to get into the bios and go to boot options, what boot options do
    you have?
    If you go into the bios you should have the choice to boot from ide
    (hard drive), cdrom, floppy disk, network (on some) and try other boot
    media.
    Are you going into the boot option in the bios by pressing F2.
    when
    you press f10 that gives booty options. Try pressing F2 when the
    computer boots and go into the bios to change the boot options.
    Give it a go
    Okay
    then then F2 is not the button for you. Some computers go to bios by
    pressing F1 or the delete key when you boot. Try both of these one at a
    time to get into the bios.
    If you have the last good known configuration screen up try choosing
    that option first. If no luck try what I said above. Boot your computer
    and keep pressing the delete button until you hear a beep, if that does
    not take you into the bios then reboot and try pressing the F1 key
    until you hear a beep. If the F2 does not take you into the bios then
    F1 or delete will
    Comment posted on Jan 14, 2009do you have the full version of windows and a floppy drive?
    Comment posted on Jan 14, 2009give me about 20 minutes I am just dishing up dinner and I will get back to you :)
    Comment posted on Jan 14, 2009just
    before I go for my dinner try booting and pressing the delete button to
    enter your bios, you have not said if you have tried that already or
    not, but i believe your model requires you to press the delete button
    to enter the bios
    Comment posted on Jan 14, 2009Okay
    so when you press f10 you say that takes you into the bios? If you do
    get to the bios from there do you have an option any where to load the
    fail safe settings? If you do try this
    Comment posted on Jan 14, 2009have you tried setting mulitibay as priority boot option 1?
    http://unmountablebootvolume.windowsrein...
    look here for some ideas on correcting the problem,
    Comment posted on Jan 14, 2009does
    your laptop have a recovery partition? If it does you may be able to
    recover your drive to the factory default settings by pressing Alt and
    tap f10 continously until the recovery manger comes up when the
    computer first boots and the compaq screen appears
    if everything you have tried does not work then go to this link http://h20000.www2.hp.com/bizsupport/Tec... and it will take you to the hp support site with solutions to this error and how to prevent it from happening again.
    I hope I have been of some help
    Comment posted on Jan 14, 2009okay
    i hope you get it sorted, i know on one of my other computers i had to
    set all of the bios boot options to cd before it would actually pick
    the cd up to boot from, maybe you could try setting both options to
    multibay put your xp cd in and boot again.
    Let me know if you get it sorted!
    f7 does not do anything. f8 takes me to advanced windows option which again does not have the option for boot from cd. on bios i have 3 options: multibay, hd bay and network bay.
  • DEKR
    DEKR May 11, 2010
    k your trying to boot up with windows cd or system just won't boot.
    can you get into safemode by continuosly pressing f8 during a restart
  • DEKR
    DEKR May 11, 2010
    please tell me more of the problem
    i gotta leave in 20 minutes but only be gone one hour
    Genius:
  • Compaq Master
  • 1,102 Answers
Have you recently changed your memory
You can press f7 continuoasly while restarting
you should get an option in that for different boots
go to cd rom or cd/dvd boot
let me know how thta works
we'll try something else
Posted on Jan 15, 2009
  • DEKR
    DEKR Jan 15, 2009
    have you recently changed your memory
List down the top 2 cowboy boots for women?
The top 2 Cowboy Boots For Women are:-
1. Ariat Women's Legend Western boots - Ariat boot is one of the best pairs of boots from Ariat, it may look cute but they are also tuff and durable. Available in various colours and shades, the square toe shape or booster bed make this boot more comfortable.
Features:
It has duratread sole
It has leather lining
Full-grain foot and upper
Square Toe
2. Justin Boots Women's 12 stampede boot:- This boot is made from fine quality leather and having a durable rubber sole. Stampede boot is ideal for the women for all things country and western.
Features:
Rubber sole
Imported
Removable insert.
Oct 11, 2017 | Miscellaneous
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Write down about the women in cowboy boots?
Nowadays women's didn't take long to follow the lead of their male counterpart.Cowgirls were famous for their riding and ranching skills. Some of the Cowgirls went on to become legendary figures in rodeos and Wild West shows, and surely their boot also goes with them.
Today cowboy boots are important for every woman who is fashion conscious and want to adopt the cowboy attire. There are various Cowboy Boots For Women are available, the women's can project whichever character suits and whichever mood she feels at a time.
Oct 11, 2017 | Clothing
What can I do to boot my PC without using the F8 key?
If you have to select the boot device every time, this means that the BIOS (CMOS) setup does not have the boot device listed as the first device to boot from. At startup, press the key that enters CMOS (BIOS), usually DELETE, or possibly F2. Once in the CMOS, look for boot options, then boot devices, then boot sequence. Find your device and ensure that it is listed first in the boot order sequence. Then save the changes and reboot. You may have it set for a USB or network boot first and it won't boot without intervention.
Aug 15, 2016 | Computers & Internet
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
Is it possible to make two hard drives into boot devices?
Yes. It is called "Dual Boot" or "Multi-boot". You can even have different operating systems on each drive or partition. For more information, just click this link.
Feb 16, 2011 | Sony VAIO Digital Studio PCV-RS410 PC...
Why won't my computer boot to the A drive?
Because the BIOS is probably set to boot the hard drive first. The A drive, second or third depending on the boot order set in the BIOS.
Nov 23, 2010 | Computers & Internet
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Snowboard boot type
"Snowboard Boots - Function and Types of Snowboarding Boots Good Snowboard Boots should give you maximum control over your Snowboard, protect your feet and ankles from the pressures of high speed turns, and keep your feet warm and breathing in all weather conditions at the same time. Boots come in many variations and Styles. There are Different Types of Snowboard Boots appropriate for the Three Riding Styles in Snowboarding. Currently, a lot of boarders prefer soft boots with Strap Snowboard Bindings, but step-ins are a convenient alternative. What follows are descriptions of the most common types of Snowboard Boots: Soft Boots Softboot Soft Boots are most comfortable and can be used with highback bindings and flow-in bindings. This type of Snowboard Boots allows for a large amount of movement in just about any direction. Consequently, soft boots are a must for pulling tricks since they are great for doing whatever you want. Soft Boots consist of two parts: an inner bladder and an outer boot. The inner bladder is padded to keep your feet warm, dry and protected from heavy impacts. It usually has its own lacing so you can tighten the inner bladder independently from the outer boot. The outer boot has a sturdy upper part that allows for ankle movement. The outer lacing allows you to further tighten the Boots. In contrast to Hard Boots and Ski Boots, Soft Boots are pretty comfortable for walking and even driving your car when you're not on the board. Soft Boots are currently the Most Popular Type of Snowboard Boots and are preferred by Freestylers and Freeriders. Although there is a wide range of Soft Boot Styles for both Freestyle and Freeride Snowboarding, the main difference in the different styles is in the degree of Boot Flex. Soft Boots with a stiffer upper boot and a higher cuff with a lace-up inner boot for enhanced firmness are Freeride Soft Boot Styles. Conversely, Soft Boots with loose, molded-foam inner boots for more flexibility are Freestyle Soft Boots. Hard Boots Hardboot This Type of Snowboard Boots is designed for precise control. Hard Boots support your foot, ankle, and lower leg firmly, making them best for racing and high-speed carving on hard snow. Hard Boots have a padded inner bladder similar to the ones in Soft Boots. The outer shell however is made out of hard plastic and is usually adjusted (or closed) using buckles or ratchet bails. The benefit of having hard plastic as an outer shell is that it gives riders more precision and power in edging movements. Hard Boots resemble the traditional Ski Boots. However, the Hard Boots have lateral mobility for the ankle. To provide some flexibility, hinges are often built into the ankles. The soles of Hard Boots usually have a mechanism that allows them to be connected to Plate Bindings. Hard Boots are often used with plate bindings by Alpine Racers who want their movement to be directly transferred from the Hard Boots and Snowboard Bindings onto the Snowboard. On the contrary, Hard Boots are not suitable for Freestyle Snowboarding tricks and maneuvers since they limit the amount of flexibility. This Type of Snowboard Boots is pretty specific and seriously lessens your freedom in choice. If you're planning to buy this, make sure you find an exact match between the Binding Mechanism and the Hard Boot Mechanism. Also, make sure you can flex the Hard Boot forward easily and smoothly so as to avoid mishaps during transitions. Hybrid Step-In Boots Hybrid boot These Snowboard Boots are a good choice for those who want the convenience of a strapless system. Hybrid Step-in Boots combine the flexible, soft upper part of Soft Boots and the sturdy hard soles of Hard Boots. They are used in combination with Step-in Bindings. People who are looking for a mix between the comfort and flexibility of Soft Boots and the control of Hard Boots will often opt for Hybrid Step-in Boots. As with Hard Boots, you will need to find a match between the Step-in Binding mechanism and the Boot mechanism. Before you buy Snowboard Boots, you must first decide whether you want to go with a Step-in Binding or a traditional Strap Binding. Remember, while traditional Strap Bindings will work with any non-Step-in Boots, Step-in Boots must be purchased together with their corresponding Bindings. Also, keep in mind that Hard Boot systems work best in harder snow conditions, while soft boot systems work best in softer conditions. "
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
Compaq Evo N610C Notebook Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
