Question about Toshiba Satellite L45-S7423 Notebook
Toshiba Satellite L45-S2416 hdd password locked
I have a satellite l45 and when its turn on, a hdd pasword is required to continue. How i reset this password, my brother set the password and not remenber them.
What year was this laptop made toshiba satellite pro l450d 12x
Since it has a dual core and pre-installed with Vista Home Premium - about five years ago for Toshiba Satellite L45-S7419 15.4-inch Laptop. For the toshiba satellite pro l450d - about a couple years ago.
Nov 22, 2010 | Toshiba Satellite L45-S7419 Notebook
Toshiba satellite L45 has BIOS password, which is lost How do I reset it?
  1. Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
  2. Click Start, and then click Run.
  3. In the Open box, type “control userpasswords2′, and then click OK.
  4. Click the user account that you forgot the password for, and then click Reset Password.
  5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
May 01, 2010 | Toshiba Satellite L45-S7423 Notebook
L45-s7409 processor upgrade toshiba laptop
It appears you cannot upgrade this unit, the CPU is soldered down.
Mar 29, 2010 | Toshiba Satellite L45-S7409 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Cant get audio driver for a satellite l45-2416
was your computer running vista before hand if so use microsoft update to get updates and do custom intall instead of express after you get sp3 then if they have your driver for you hardware listed under hard ware tab on menu select it
Mar 16, 2009 | Computers & Internet
UNLOCKING MY TOSHIBA SATELLITE L45-S2416
Can you tell me whether this is a bios power on password, a hard drive lock password, or a windows administrative operating system password? I'm assuming that it is asking for a password when you say "locked".
Sep 05, 2008 | Toshiba Satellite L45-S7423 Notebook
How to install XP on Toshiba Satellite L45-S7409
You need to integrate the SATA driver to your XP install CD.
Apr 04, 2008 | Toshiba Satellite L45-S7409 Notebook PC
Open Questions:
Toshiba Satellite L45-S7423 Notebook Logo
443 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
